Converting LHD to RHD
Moderators:iRS, Art1012
Mk2600FGJ
Postby Mk2600FGJ » Mon Apr 19, 2010 11:18 pm
Hello all, can anyone advise me on what i need to acquire to carry out the conversion from LHD to RHD and what, if any parts can i retain to do the switch in order to keep costs down. Subject car is a 1968 series 1 1/2 4.2.
Amendment to ad:
Is there any alternative power assisted rack i use other than E Type. I would expect a long search to find a rack from an E Type.
Thanks Eugene.
PoB
Conversion
Postby PoB » Tue Apr 20, 2010 9:42 am
For starters:
Steering Rack
Both side dash panels
Pedal Housing
Steering col shroud (fitted on engine side of bulkhead)
Headlights
Brake/Clutch res' brkts
I don't know if your ignition key is dash or col' mounted, if col' then it might end up on the wrong side of the col, if that bothers you. You will also have to turn the wiper crank arm through 180 degrees and buy 3 wiper arms to be correct. Fit new brake pipework and clutch pipes as necessary.
Pat
PoB
conversion
Postby PoB » Tue Apr 20, 2010 6:21 pm
Forgot to add... only need to change the pedal housing if you have the early cast/fabricated housing, if the later then you will need to alter the angle of the clutch pedal
Pat
Mk2600FGJ
Postby Mk2600FGJ » Tue Apr 20, 2010 8:59 pm
Many thanks for that Pat.
Thats a great help to know what all i need.
Now i shall start searching.
If anyone has or knows where i can locate these items please drop me a PM.
Any help is always appreciated.
Eugene.
DaveK
Postby DaveK » Tue Apr 20, 2010 10:45 pm
Eugene,
On top of what Pat mentioned you will either have to replace the wiring harness or extend the one you have.
The wipers arms can be heated and cranked the opposite way then polished.
The steering column can be simply turned through 180 and the so the indicator stalk is on the correct side.
Accelerator linkage, though some of it can be shortened and reused.
The rear/front sidelight and indicator light lenses may also be different depending on where the car came from.
There maybe some other small items that I can't remember just now.
As for where you get the parts from it depends on whether you want original or repro parts, any of the usual vendors sell each part, people like RM&J Smith will sell you original parts but they are expensive.
If you want power assisted steering a good alternative is the electric power steering that Uryk from E-type fabs has started to manufacture.
Do a Google search for E-Type fabs.
Dave
Mk2600FGJ
Postby Mk2600FGJ » Thu Apr 22, 2010 11:22 pm
Many thanks for that Dave. Your response is greatly appreciated.
Eugene.
MT2+2
Re: Converting LHD to RHD
Postby MT2+2 » Tue Apr 23, 2013 1:18 pm
Hello Eugene,
Did you go ahead an convert to LHD, and if so do you have any tips to share?
I am considering converting my LHD 1966 S1 2+2 4.2.
Martin
