Steering Rack, can it be refurbed DIY?
Moderators:iRS, Art1012
Azzura
Postby Azzura » Sat Dec 01, 2018 5:05 pm
1969 Series 2 - 4.2
I have checked the steering rack prior to work on the suspension. On the passenger side there is quite a bit of play when I move the road wheel (when it is jacked up) from side to side.
The other side is fine.
Looking at a parts diagram there is a nut and a spring and I have seen you can tighten this to create friction. Would tightening this nut be the answer?
If not can I rebuild part of the steering rack as it just seems worn on the one side?
PPV
Re: Steering Rack, can it be refurbed DIY?
Postby PPV » Sun Dec 02, 2018 11:54 am
Hi, although I do not have a steering rack I came across this site whilst looking for help in working on my Mk2. It seems to go through everything in detail and may help: https://themotorphile.com/2011/12/22/ja ... ng-rack-2/
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
piman
Postby piman » Sun Dec 02, 2018 2:12 pm
Hello Azzura,
is the play in the knuckle joint where the track rod connects to the rack? If so they are normally adjusted by shims so should be quite a practical job. Probably worth replacing teh boot at the same time?
Azzura
Postby Azzura » Sun Dec 02, 2018 2:42 pm
Thanks for the two responses, most helpful.
I should have said it is not power steering but the information is very useful.
Nice to get a response too.
Hi Alec, I know you have replied to at least one of my previous posts from last year so thanks again.
I am looking for a bit of guidance on the rear suspension, have you worked on this?
In particular I have seen the car sits a little high at the back. The drive shafts do not sit straight, pointing downwards from the diff to the wheels. The rear wheels have a little bit of positive camber and the car does not feel planted in corners. There are red Koni shock absorbers all round. I just wondered if whoever fitted them used the correct length springs on the rear. Information from the forums on riding heights tells me it could be at least 1 1/2" too high, a level on the sills confirms it sits higher at the rear of the car.
Any advice most welcome.
Roger
piman
Postby piman » Mon Dec 03, 2018 10:44 am
Hello Roger,
The knuckle joint I am referring to is the same whether power or not,. The other point of wear on a steering rack are the bushes at either end of the rack tube, if the rack itself can be moved up and down that indicates wear of that bush.
I haven't worked on the rear suspension but it doe sound as though the springs are wrong, although it's worth a check to see if any packers have been used under the springs? (I can't imagine why, but it's worth a check)
Certainly you should have some slight negative camber on the rear.
