Series 3 OTS 1972 Brake light switch
Moderators:iRS, Art1012
pgxxl1959858
Postby pgxxl1959858 » Fri May 07, 2021 5:08 pm
Hi Anyone
know of a suitable replacement brake switch which is more rhobust than the standard plastic.
piman
Re: Series 3 OTS 1972 Brake light switch
Postby piman » Sat May 08, 2021 8:01 am
Hello Paul,
I'm not familiar with your car but I assume that rather than a hydraulic pressure switch, the brake light switch is actuated by the brake pedal?
If that is the case I would suggest that you look at industrial limit switches. They come in a variety of sizes and mounting options.
One website that keeps a large variety is RS-Components https://uk.rs-online.com. Just ensure the correct configuration of the contact if you see one that seems to be suitable. Either a change over configuration or a normally closed configuration.
