Removal of transmission
ihopland
Postby ihopland » Sat Dec 29, 2018 8:34 am
I am removing my transmission on my car and I have some questions.
What are the best ways of removing the connectors on the transmission ?
poprivet
Re: Removal of transmission
Postby poprivet » Sat Dec 29, 2018 4:19 pm
It depends on what year your car is and whether it is an auto or manual, I assume you mean removal of gearbox.
Do you have a fault on it? many problems can be solved with the box in situ. If by chance you have an early ZF auto on an XJ40 I have the same gearbox on my XJS which I have changed in the past so may be able to advise.
naki
Postby naki » Wed Jan 02, 2019 11:19 am
There’s two possibilities on the oil cooler lines for the ZF Autoboxes.
The earlier models have a Banjo bolt set up (better). The later versions a straight screw fit. these can be more problematic potentially, with restricted access for an open ended spanner, on the lower line under the box.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
