X300 Cuts out when up to temperature
Hello, has anyone out there had this problem or more importantly, found a cure? Engine will misfire then cut out. It will start and run after 20 min cool down. Getting Desperate!! thankyou. Graham
Re: X300 Cuts out when up to temperature
Quick diagnosis....possibly a faulty cylinder head temperature sensor to be found near the thermostat. These sensors do not last for ever. They are likely to break down and cause false readings to be sent to the power train ecu. Faulting is highly likely to upset fueling parameters.
Others on this site may be able to offer better first hand knowledge and offer an alternative reasoning.
Many Thanks Mike, I will pass on info to my guy working on it. Graham
Hi All, just in case this happens to you, the fault was cured by replacing the fuel filter. Thanks to all replies. Graham
Thanks for the update Graham,
Good to know you got it sorted.
Take Care.
Take Care.
This topic has been moved to the 'Engine' Section.
2003 X350 XJR - daily driver
Past vehicles:
Past vehicles:
