The heater flaps on my 1965 S type are stuck (in the hot position) - the small lever on the side of the heater is seized even with the control cable removed.
How is the heater attached to the bulkhead, how many screw/bolts? Anything to look out for?
I'm keen not damage the insulating material too much.
I'm slowly working through the niggling faults on this recently acquired car.
Thanks,
Simon
Removing Heater S-Type
I did this a month or so ago now - it was very easy.
Four screws and no need to damage the insulation. Once on the bench the flap freed up easily.
On examination I think I could have done it in situ. Plenty of penetrating fluid on the shaft ends, a brave heart and a pair of pliers on the 'free' end lever (the one that the cable isn't attached to) should have been enough.
Simon
Simon
