Hi can anyone help my auto box has been working ok , until i had the car jacked up front end only for about 6 weeks,now when you go to pull off, it almost seems like it is a clutch slipping, you have to rev the engine very high for it to pull away can a body help, i feel like i am riding the clutch i no that i am not
65 s-type auto box trouble
Re: 65 s-type auto box trouble
Hi Andy
if you can gat on the Rover P6 forum site there is a chap who is called Harvey who has worked on the Borg Warner gearboxes all his working life, what he does not know about these boxes is not worth knowing.
It was Harvey who enlightened P6 members about the oil specifications for the gearboxes
Regards John.
PS I have entered your problem on the P6 forum so hopefully a reply will come
Regards John.
Hi Andy
I had a reply from the chap I talked about (Harvey) but I was a little disapointed with the reply. He said that possibly the raised incline from the front may have cause a leak at a point abover the the normal level point, He did recognise the correct gear box a DG unit or it should be.
Sorry that there was no more detailed info, but maybe others will reply.
john
john
ecosselynx
I'm no expert on auto-boxes, but you never mentioned if any oil leaked out of the prop shaft seal while it was jacked-up! If the oil level has dropped then this could possible be the cause.
I'd suggest you drive it around and use the speed-hole to try and ensure all the chambers are full of oil, park it on level ground and check the oil level is correct.
bye-o
John H.
John H.
