Hi all,
I've noticed that the drivers door on my S1 2+2 has dropped a bit, so I've just had the door card off in the hope that a couple of bolts needed tightening.....of course that isn't the case! There's a "pin" that runs vertically between the part of the hinge that is bolted to the door and the part bolted to the bulkhead and it's there that there is play.
I don't know if it's possible to replace the pin, or if it means a complete new hinge, but thought I'd ask the assembled experts before helping SNG B increase their profits!
Any advice welcome! Cheers, Simon.
Door dropping...new hinge?
- greensimonc
'66 E Type Series 1, 4.2l 2+2 Auto
MY23 E Pace P300e R Dynamic SE AWD PHEV
Tiger Cat E1
gone and much missed:
'63 reg XF Sportbrake 3.0 v6 Diesel S Premium Luxury
Tiger Cat E1
Re: Door dropping...new hinge?
Hi I have a 1969 2+2 and many years ago now I overhauled my hinges. If they are not to badly worn they can be opened up and a larger pin fitted. I was lucky enough to have an engineering machine shop so did them myself. Be aware that the doors are extremely heavy and fit very close to the wing. Its a two person job to remove and refit. Try getting a cost for new hinges to compare with repairing them. If an oversize pin is used I think I used silver steel but a good grade steel is okay. Cheers John.
If you go online and put in NewHill Garage Article 9 it shows you how to refurbish a hinge. Cheers John.
- greensimonc
Thanks John, I'll do the research and comparison! Will update in due course.
Simon.
Simon.
Tiger Cat E1
Tiger Cat E1
