Accessory Drive Belt et al
rosemary
Postby rosemary » Tue Sep 08, 2015 10:31 am
Ref 2005 S Type 2.7 diesel
I have a squeak coming from the area of the Accessory Drive Belt, sometimes referred to as the Serpentine Belt. It emits a loud squeak when I turn the engine off. The car is 10 years old and has done 129,000 miles so I think the belt is due for renewal anyway but the squeak sounds like a dry bearing and suspicion is falling on the Belt tensioner although I'm not sure, could it be the water pump or something else. How easy is it to change the Belt and how do i determine what's squeaking. I was going to give the job to my local Main Dealers, phoned them for a cost indication, they said they would ring back but neither did. Any suggestion would be gratefully received. :(
Dave Hart
Martec
Re: Accessory Drive Belt et al
Postby Martec » Tue Sep 08, 2015 3:41 pm
Hi David,
I have no experience of the Diesel engine, but assuming the same procedures would have been used on petrol and diesel.
Make an accurate drawing of Your belt run.
The petrol engine belt tensioner is simply spring loaded and it quite strong, but a big spanner or shifter can be use to move it back and remove the belt from any covenient pulley, then the rest the spanner against something. From there you can remove the old belt and thread the new belt into place except for the 'convenient' pulley, move the spanner to engage the belt onto the pulley and bob's your uncle.
Its a good idea to compare the old and new belt lengths to be sure you have purchased the correct belt.
rosemary
Postby rosemary » Tue Sep 08, 2015 5:16 pm
Thanks Brian
I might have a go if I can pluck up the courage. I still need to determine what's squeaking though.
`David
Dave Hart
Martec
Postby Martec » Tue Sep 08, 2015 6:48 pm
Find a spray can of silicon, furniture polish will do if necessary, spray that onto the belt when it is turning, if the noise shuts up its the belt. Many years ago I had a cambelt do the same, silicon spray from time to time quietened it down and did no damage (advised by the MOT guy).
Best of luck
rosemary
Postby rosemary » Wed Sep 09, 2015 7:27 am
Hello Brian
Will do,the belt looks to be in good condition although I can't actually see the marks on the tension indicator to check if it has stretched. There must be some technique to do this. I had the Cam belt changed at 86,000 miles at my local main dealer because they said it was shredding, I do wonder about what they did.
David
Dave Hart
