XJ8 climate control module
Roger2845
Postby Roger2845 » Fri Aug 21, 2015 5:18 pm
I have been having trouble with no heat in my 1998 XJ 8 Sovereign. So far I have eliminated the air-con water pump (works ok) have had a replacement heater valve fitted ,and fuse and relay ok.The problem is that no signal (power) is getting to the relay so suspicion now centres on the air-con/climate control module. Can someone please tell me where to locate this module so that I can obtain and fit a replacement.
Re: rear quarter lights
Postby davidr » Fri Aug 21, 2015 10:08 pm
It may be that the process has got out of sequence. I would try opening the roof fully again and then trying closing it. This usually works on my XJS when it gets confused.
