Failsafe Engine Mode
sheldon1
Postby sheldon1 » Mon Aug 10, 2015 11:56 am
Ive recently had the message failsafe engine mode come up on the dashboard of my Jag 3.0 Se
I think the throttle body needs cleaning out. Having not cleaned one before , whats the best method and which cleaning additives to use?
Re: Failsafe Engine Mode
Postby J44EAG » Mon Aug 10, 2015 3:38 pm
Hello Paul.
Take off air trunking to access throttle butterfly plate. Wear nitrile gloves as this is a messy job. Open the butterfly by hand and chock open with an appropriate sized soft screw driver handle. Clean the plate and PTFE covered throat with a soft cloth and carburettor cleaner. That might help with the issue.
I wrote an article some years back on throttle operation having had a throttle cable socket connection fracture on the TAC module on the throttle. A cheap ebay £25 throttle completely sorted the issue. New a throttle is around £1300 from Jaguar although BBA Reman can recondition for around £400. Check the wiring plug is fully home in the throttle socket and a good connection being made. Failure from that cause is rare though. The same for the throttle position potentiometer which is relatively reliable but not available separately from a new throttle body.
Most limp home issues stem from the throttle pedal and its built in potentiometer. The pots can go bad if subject to damp. A night on the boiler may cure the issue so try that before buying a complete new pedal assembly.
Best to have the car scanned to try to get a good insight into throttle maladies. Well worth buying a Jaguar dedicated scanner such as the iCarsoft 930i for around £90 from UK Diagnostics or if you have an Android phone, download the Torque app, upgrade to the full version for around £3 and then buy an ELM327 blue tooth OBD car plug in chip for around £7 from ebay. Both useful units where diagnostics are needed. I have an ELM permanently plugged into my car and it takes only seconds to diagnose the car if something crops up.
Let us know how you get on.
sheldon1
Postby sheldon1 » Mon Aug 10, 2015 5:01 pm
Thanks Mike,
Worked it out . unscrewed the jubilee clip and detached the two wiring connections. Got a rag and pushed the butterfly flap open and cleaned with a carbertter cleaner. sprayed the two electric sockets and wiped away surplus and re attached .
Failsafe engine mode message dissappeared.
Do I need to do anything with maf sensor next to my aircleaner?
Thanks Mike.
Postby J44EAG » Mon Aug 10, 2015 5:19 pm
Remove the Torx head screws and remove the MAF sensor from the housing. Use spray carb or switch cleaner to clear any crank case breather sludge from the delicate hot wire. Don`t touch with any implement for obvious reasons. Re install and that should all be good.
