Fault-finding on the Delanair Mk III (facelift cars)
PaulGover
Postby PaulGover » Thu Aug 06, 2015 11:28 pm
I've just spent an age researching and testing the air-con fitted to my facelift V12. I'm sure it's worth sharing the experience - "a trouble shared is a trouble doubled" :)
My problem was that only the driver's side fan only came on in Defrost and full cooling/heating modes - i.e. it only ran when the ECU decided it needed full air, and tripped the relay.
I'd already taken the fan out, and checked its power MOSFET (which often fails), and it was OK. In fact, I'd replaced the MOSFET about 5 years ago because it had indeed died.
The best diagnostic guide is in Jaguar's "Service Product Training - Delanair Mk III conditioning unit - Fault Diagnosis". It's on the Jaguar Heritage DVD of "XJS Supplementary Information" part no JHM1123 (still available at £25). I expect, but don't know for certain, that the newer combined "Jaguar XJ-S, XJR-S and XJS - 1975 to 1996" DVD (£50) also contains it.
My copy has some paging problems - towards the end, it includes spurious pages from a BL manual on electronic ignition.
It's got a nice series of checks to work through to identify faults in the electronics and vacuum system. However, it starts by suggesting you build a diagnostic box connected to three 15-way plugs to go into the diagnostic sockets on ECU (RHS side of the air-con unit, above the lower air outlet). Good luck with finding a supplier of said plugs!
My alternative was a trip to Maplin to buy a box of 4 "single pin cables" (part no A39GF, see here) for £4.
You solder a wire to lengthen them, and then connect to the other essential, a digital volt meter. (Maplin currently have one suitable, N15BY, at about £10). Insulate any joints, as a short might fry the air-con ECU. With these, you can slide one connector over pin 45 (the lowest pin on the lowest of the three diagnostic sockets) for ground, and another connector over any pin of choice to compare its voltage with the fault-finding instructions. Access is easier if you remove the instrument panel - everything appears to work OK with it removed, though cover its plugs with cling film or a plastic bag to avoid shorts.
The diagnostic guide says to have a means to short a couple of pins together. As above, this is very dangerous - miscount your pins and you fry the ECU. The first short is to get manual mode, but that's identical to pulling out the temperature-setting knob (LHS). The second is to replicate the water temperature sensor, and is only used for the final tests of fan speed. Instead of this shorting link, you can pull the leads of the sensor (it's on the LHS of the air-con unit) and short them together.
When I got to the last section of the tests, the problem with my fan was clear. The voltage to its speed control (pin 32) was nearly 4V, while the corresponding one to the working LH fan (pin 31) was 1-2V, the correct range.
From what I've seen on the web, speed controls for DC motors typically use a power MOSFET to switch the motor power on and off rapidly, varying the ratio of on to off to achieve the desired speed. So the voltages listed will be an average depending on how much the motor's being switched on. The ECU receives a feedback signal from the motor, so it can sense how fast it's spinning. 4V means it was trying to turn it on 100% of the time, which means the signal wasn't getting through.
I therefore used the multimeter to read the control voltage at the fan circuit board while switching the fan speed up and down. Nothing much, bad connection from the meter probe. So I pressed a bit harder - 1.8V, and the fan leapt into life! Peering at the connection with a magnifying glass showed a dry joint where I'd replaced the MOSFET, and pressing hard made a connection. Ouch! So I'd spent the best part of a week, and dismantled half the dashboard, for something fixed in 5 mins with a hot soldering iron. C'est la vie.
BigCatXJS
Re: Fault-finding on the Delanair Mk III (facelift cars)
Postby BigCatXJS » Mon Aug 10, 2015 5:42 pm
Thanks for sharing. Mastering the Delanair can be a dark art! If you managed to bag some pics along the way - this would make a great article for the XJS Forum pages in the Club magazine. Please let me know if you can.
Ta, Rich
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
PaulGover
Postby PaulGover » Thu May 26, 2016 11:45 pm
Belatedly, I have some photos - first batch of three. (I have the originals in higher definition, if anyone wants them.)
1 - the mare's nest wiring under the (RHD) driver's dashboard.
2-The 15-way plug (you can just see its socket below to the right - note the bulletin board rotates the picture; click on it to get a bigger, correct, image ). If you can get one of these, you can wire up a proper test rig.
3-The view down through the instrument panel aperture. The blue colour marks the 15-way plug in its normal socket; the diagnostic socket is to its right.
PaulGover
Postby PaulGover » Thu May 26, 2016 11:50 pm
And three more:
4-Attaching a Maplin "single pin cable" to one of the diagnostic pins
5-My printed copy of the Jaguar Delanair Mk III training manual, from the DVD
6-One of the pages of checks.
PaulGover
Postby PaulGover » Thu May 26, 2016 11:54 pm
And finally, a simple modification to the centre air vent to get more through the steerable vanes, and less aimed at the rear windscreen. The wooden cover pulls/levers out (with care, of course, you don't want to damage it). So does the plastic vent (probably dislodging foam sealing strips, hair-clips, bits of chocolate and pizza, etc).
The mod is to put a piece of black card across the middle part of the vent, held in place with (fittingly) duct tape.
Paul_1959
Postby Paul_1959 » Sat Jun 18, 2016 2:54 pm
Really useful posts.
Just like to add to add a couple of useful documents (uploaded to mega as unable to upload PDF document here)
https://mega.nz/#!zcBVCJpI!Qzdok8XOS9S3 ... JiAnuvNkvQ
Delanair mk iii introduction
https://mega.nz/#!iRhW2bqK!hZFG251t6jvg ... tevzX-NFcg
XJS mk iii climate control
1993 XJS 6.0 V12 Coupe
