ELM327 OBD2 Car Diagnostic Scanner CAN-BUS Bluetooth / WiFi
Ossycat2003
Can anyone recommend or steer me clear of the relatively cheap (£10-£15) diagnostic tool available on ebay & Amazon that works in conjunction with an App for Android smartphones?
Re: ELM327 OBD2 Car Diagnostic Scanner CAN-BUS Bluetooth / W
Several of us are successfully using a downloadable Android app (£3 buyes the proper upgraded version) plus a Bluetooth ELM327 chip unit from ebay for around £7 to fit the OBD port on the car. Mine works well and has all the functions of an iCarsoft 930i dedicated £90 tool which I also have.
I`ve several disc programmes, Windows XP based, which work reasonably well on an old XP laptop. Use on Vista or W7 based laptops has been less successful with loading difficulties being experienced even though sellers claim their discs work well with Vista or XP systems.
Hope that helps.
Hope that helps.
try an XP emulator program loaded onto your Vista etc laptop,( large HD required though ) then run the ELM software on the XP emulator
its an operating system within an operating system
i went the whole hog and got a full Jaguar diagnostic program running on an XP laptop and a ' mongoose ' USB interface lead that plugs direct into any Jag before 2014 ( OBD1 & 2 ) and can fully interact with the firmware on the car changing anything i want
i got it so i could add the 6 cd changer to my wife X-Type , lol
Hello Brake Buster,
Tell us more about mongoose and the Jaguar software.
I looked at this about 18 months ago and came away confused and suspicious that some souls were trying to sell something that would not work without a Jaguar subscription at significant cost.
There seemed to be various versions and options, which when I Googled came back with "do not trust" and "could not get it to work" replies. I gave up.
Doug Barrass.
Ashford, Kent.
(I could actually drive freely round Ashford today as Operation Stack was gone!!)
Doug Barrass.
Ashford, Kent.
Hi Guys
Be careful what you buy
Having a OBD2 Socket under the dash does not make your electrical circuits OBD2 compliant!
X100's to MY2002 (I do not know about post MY2002) are not OBD2 compliant (MY2002 has a OBD2 Socket but OBD2 only Readers / Software do not work)
Some of the WiFi/Bluetooth OBD2 Units do work with my XK8 but I suspect the cheaper ones are OBD2 only
AllanJ
AllanJ
XK8 Registrar
Ossycat2003
Thanks guys .......................
