This morning, I started the engine to check for leaks and levels before going out but I noticed the engine was running rough, after checking that all leads were connected properly, I pulled the spark plug leads off one at a time with the engine running and sure enough number 3 was the culprit, not firing.
Put an old plug on the lead and earthed out on the cam cover, yes sparks. Took the new plug out and tried that in the same way, yes sparks. A bit more head scratching, swapped spark plugs but number 3 still not firing.
It was only then that I noticed the electrical connector on number 3 injector was off! I expect it had dislodged when I was pouring in the new oil. Shame I didn't spot that earlier, it would have saved me an hour
