Rear Suspension Bump Stop
Popsjag
Postby Popsjag » Sun May 24, 2015 7:57 pm
M.O.T. due on Tuesday & noticed that one of the bump stop rubbers has partially come away from the cast mounting plate. No problem - I'll just pinch one off Zac (now being stripped as rot is far greater than first appeared!).
Not so straight forward! - see photo. Left one is the damaged one from my Sovereign. Right one is the one off Zac. See the difference? One bigger than the other!
So I will have to change both of them as a set - more work!!
It appears that MNA3750AB is fitted to the 4 ltr supercharged model (but must have been fitted to Sport as well because Zac is a 3.2 Sport).
MNA3750BA is fitted to all other models - unless someone can enlighten me further?!!
2003 X350 XJR - daily driver
Past vehicles:
naki
Re: Rear Suspension Bump Stop
Postby naki » Wed May 27, 2015 2:04 pm
I would use it regardless. new ones arent too cheap for what they are.
i have re[paired them before too.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
Popsjag
Postby Popsjag » Wed May 27, 2015 9:04 pm
I did Naki - and it passed MOT, next day, with just 1 advisory - slight play on nsf inner tie rod.
Past vehicles:
naki
Postby naki » Sun Jun 07, 2015 12:29 am
thats a good pass in my book. its rare i get less than 3 advisories on any of my lot.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
03 X350 4.2 XJR
DirtboyNay
Postby DirtboyNay » Tue Oct 02, 2018 5:48 pm
I have a 2003 Jaguar XJR R1 with 8 x 18 ET 33 BBS Milan Wheels. I recently purchased 9 x 18 ET 35 BBS Milan Wheels for the Rear.
The big wheels have caused the tires to rub on the bump stops MNA3750AB. I was advised to halve out the original bump stops. Or I could replace them with bump Stop MNA3750BA which smaller and came on the earlier 94 - 97 Jaguar XJ6. Will these bolt up without any modification ? Any advice will be appreciated.
