Back axle - thicker oil option?
Moderators:robv12, DavidEm
XJ_Driver
Postby XJ_Driver » Thu May 14, 2015 4:38 pm
I have noticed a slight 'clonk' from the back axle on my XJR starting to develop when moving off from rest. I am thinking about changing the axle oil. I read on another post that Millers Transax 75/80 (or equivalent) is recommended, but would a slightly thicker oil (to counteract wear in the axle) be advisable? At one time I would have simply added a can of STP or similar, but may be that's a low tech approach to take these days?
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
oldtimer
Re: Back axle - thicker oil option?
Postby oldtimer » Thu May 14, 2015 6:31 pm
What makes you think the clonk is coming from the Diff. There are plenty of other items that might well go clunk in the night. Sorry to say that a change of oil grade is highly unlikely to eliminate a clunk.
XJ_Driver
Postby XJ_Driver » Fri May 15, 2015 8:51 pm
True enough, but this does sound like diff to me.
I put the same question to a mate who works in the tech department at Morris Lubricants, Shrewsbury this afternoon and he suggested using their XEP80w-90. I'm going to give that a go and see if it makes a difference.
If not I shall have to investigate further!
Thanks. :)
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
