My next project on the XJS..........
Postby Brakebuster » Wed May 06, 2015 6:11 pm
can you guess what its going to be ??
BB :mrgreen:
Re: My next project on the XJS..........
Postby ptjs1 » Wed May 06, 2015 8:37 pm
BB,
my guesses:
- Nitrous
- Water injection
- Twin turbo-charging
- A tow-bar
- 4-wheel steering
- Opening front quarter-lights
- Colonel Bogey horns
- Sidepipes
- Gullwing doors
or, as with tomorrow, will it be a coalition?
Postby Brakebuster » Wed May 06, 2015 8:54 pm
hmm
now there are some interesting topics there
with regard to ' water injection ' did you know this is almost as good as using things like Terraclean ' for cleaning coke deposits out of the combustion chamber, and is an old engineering trick
the main issue is not too much water as to stall out the car, but enough to get a detonation to remove the crud, the piston tops and the valves come out like new after doing that , lol
i got a tow bar on the other jag :oops: , but it is a genuine removable one
did think about side pipes, but....
so , some great ideas, but not quite what i am attempting next
BB :wink:
Postby davidr » Wed May 06, 2015 10:57 pm
I think that, in a fit of remorse, you're going to take those centre exhaust pipes off that you stole from under my nose on eBay!! :D :D
Postby Brakebuster » Wed May 06, 2015 11:00 pm
i got some old scaffold tubes you can have if you want....................
BB :lol:
steve_m
Postby steve_m » Thu May 07, 2015 12:48 pm
Nice to be able to pick what you want to do rather than staring gloomily at the seemingly endless list of things that absolutely have to be done. Immediately.
Postby Brakebuster » Thu May 07, 2015 1:33 pm
Steve
It is essential work rather than enhancement if that helps
poprivet
Postby poprivet » Thu May 07, 2015 3:47 pm
Well. I've seen the paintwork and I doubt anyone could improve on that. I know the Mulbury seats are well liked so it can't be a change of interior. As far as I know the new gearbox is behaving so it can't be that. Wheels and tyres are already a top quality job so it won't be that.
So I'm guessing its about more power? perhaps twin turbos or a 7 litre engine :D
Postby ptjs1 » Thu May 07, 2015 4:00 pm
essential work...?
- pinhole rust on bottom of fuel tank
- faulty solenoid valves in ABS unit
Postby Brakebuster » Thu May 07, 2015 4:15 pm
we have a winner...... :mrgreen:
fuel tank , mine is 26 years old, and I'm getting debris in the sump blocking the pickup tube filter, causing fuelling issues and the car almost stalling , I have cleaned out the sump once which cured it for a while, so I think the main tank is deteriorating internally , that and a very feint smell of fuel when the boot is opened , so probably have the ' rivet ' issue on the bottom, and or a perished pipe ??
So I managed to get a new old stock fuel tank recently ( made in 1998 ), along with a new sump tank and the required pipes, as well as a brand new pump
so will be installing that little lot soon
BB 8)
Postby ptjs1 » Thu May 07, 2015 4:27 pm
BB,
I shall collect my prize at Eastern day, hopefully!
I'd also start looking for some new boot carpet and closed-cell foam for the tank mounting. I understand that once you've got the fume problem, you can never get rid of it from the mounting foam or the carpet.
BigCatXJS
Postby BigCatXJS » Thu May 07, 2015 7:10 pm
Faint wiff of fuel in the boot? I thought that was all part of the XJS ownership experience :lol:
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
Postby Brakebuster » Thu May 07, 2015 7:34 pm
but i'm going for a strong smell of fuel in the boot, :shock:
BB :wink:
( i got my monoprice HD camera today.....)
BigCatXJS
Postby BigCatXJS » Fri May 08, 2015 7:35 am
Good stuff: look forward to some V12 sounds soon then :)
Past:
1985 E28 BMW M535
steve_m
Postby steve_m » Fri May 08, 2015 8:42 am
Strangely enough I have just had the fuel tank changed in mine (corrosion and leaking seams) and also have an ABS problem.
Do I win a prize too?
