polished the headlights today , gave her back her sparkle
Postby Brakebuster » Sat May 02, 2015 4:59 pm
as with most , if not all of the X-types around the headlights suffer from UV degradation and discolouration of the lenses
this can be a problem come MOT time, but it also looks terrible on an otherwise decent car
my headlights were this bad, drivers side
IMG_2409 by MyPix on Talk Photography
passenger side , i had already tried hand polishing the outer headlight some months back but it was too labour intensive and the right amount of force and pressure couldn't be maintained
IMG_2410 by MyPix on Talk Photography
so i bought this kit on ebay for £13 to be used in a drill
IMG_2413 by MyPix on Talk Photography
the polishing bit fits like this , with a removable soft pad to apply the polishing agent
IMG_2414 by MyPix on Talk Photography
but first, you have to remove as much as the crusty surface as you can with some 2000 wet and dry paper using some water to help things along , a hand spray bottle is perfect for this
IMG_2416 by MyPix on Talk Photography
once finished with the 2000 paper the headlight will look like this, but feel smooth Image
IMG_2417 by MyPix on Talk Photography
then mask up the surrounding paint to stop any damage , and use the drill with the polishing agent and some spray water,
IMG_2418 by MyPix on Talk Photography
take your time, and make sure the headlight stays cool, as this process will warm it up rapidly and could damage the lense if not careful
this is the one side compared to the other side shot......
IMG_2420 by MyPix on Talk Photography
so , onto the drivers side, these were worse condition wise , and the one headlight had a double ' scar ' from a PO ( probably some idiot in a carpark :roll: )
IMG_2421 by MyPix on Talk Photography
IMG_2422 by MyPix on Talk Photography
same process all over again , and with some patience you can improve the look of the car immensely
IMG_2423 by MyPix on Talk Photography
IMG_2425 by MyPix on Talk Photography
once finished, there is some UV protection paste ( like sun cream ) to add , let it dry then buff it off with the supplied cloths
took me about two hours in total , a full job would involve removing the bumper and headlights and strip them down and polish the lenses , but i am more than happy with this process and happy to do it once a year if required to maintain the healthy look of the car
GreenyX
Re: polished the headlights today , gave her back her sparkl
Postby GreenyX » Sat May 02, 2015 6:59 pm
Lookin good!
GordonJ
Postby GordonJ » Sun May 03, 2015 4:04 pm
Looks good, just the post I needed to see as I must get the wives S Type done soon.
Thanks BB
XJ6 X350 Sovereign
Previous Jaguars.
XJ8 Sovereign in Seafrost
S Type in Red
Postby J44EAG » Sun May 03, 2015 8:04 pm
I have had to do the same on my MY02 S-type.
Story documented and photographed on the S-type Forum.
I used a similar method but with Fast Cut Farracla paint cutting paste and various grades of W&D production paper. However the job tends to drop back after about a year due to the incredibly destructive effects of UV. Of course the downfall with my method is that I`ve not used a UV protector because I`m a cheap skate!. I really must see if I can find some without buying the proper kit!!
Well done. It is not easy work and sometimes as you struggle to remove the tarnish, you wonder if the job will look presentable and uniform. I`ve also used tooth paste on one attempt. Something we used when I was making presentation models of Hawker Harriers and the perspex canopies had to be polished up.
I`ve tried this method on my specs as well. Not quite so successful as after cutting back the prescription changes and I wonder if I`ve done the right thing there also!
steve_m
Postby steve_m » Sun Oct 23, 2016 10:01 pm
Did the same on the Freelander yesterday; the lights were going to be an MOT fail because they were so faded and horrible.
Looked on line and the cheapest replacement lights I could get were £120 each.
Bought a kit on line for £19, took about half an hour and the lights look like new.
Well worth the time and effort.
The X Type was parked next to the Freelander and all of a sudden the headlights looked grubby.
As I had the kit out I did the X Type, small lights so only 5 minutes each, job done.
