How car electrical systems work
poprivet
Postby poprivet » Fri Nov 03, 2006 9:31 am
Electricity isn't caused by cold fusion, thats nuts, and forget all that nonsense about magnetic fields and the flow of electrons along a conductor, for it is just that; nonsense, a myth put about by auto electricians to support their lavish lifestyle at your expense. The reality is ... smoke! when you think about it, it all becomes startlingly obvious – smoke makes all electrical things function. if smoke escapes, the component stops working. For example, the last time you had to grovel under the car to replace the startermotor, didn’t it start smoking before it ceased working? of course!
The wiring loom on your car carries smoke from one device to another, pumped around the system by the alternator, and when a wire springs a leak it lets all the smoke out and everything stops. Starter motors require lots of smoke to work properly, so they have very thick wires going to them. The battery stores up lots of smoke dissolved in battery acid, which is why they were once called accumulators, until it became apparent that we unwashed home mechanics would twig to the secret. Naturally, if you try to dissolve too much smoke in your battery it will escape through those little holes in the top, which is why those batteries with sealed tops explode when they get too much smoke in them.
With regard to Joseph Lucas and his wrongfully sullied reputation, why is he so maligned? Why are Lucas components more likely to leak smoke than, say, Bosch? Because Lucas is British, and all British made things leak. British motorcycles leak oil, British sports cars leak rain, British brakes leak fluid, and British governments leak military secrets. So naturally British electrical components leak smoke. :lol:
Postby Brakebuster » Fri Nov 03, 2006 4:32 pm
well,
thats five years of learning and 22 years of doing electrical installation gone up in.....smoke :?
nice one
dhdove
Postby dhdove » Fri Nov 03, 2006 10:09 pm
Pop
Awesome....
I'm worried about what the NEXT installment might hold: :twisted:
DH Dove
XJS Bulletin Board Moderator
GlennH
Postby GlennH » Sun Nov 05, 2006 11:40 am
Pop,
Have no fear, help is at hand for those for whom all of their smoke has escaped.
Salvation is at hand on this website....
http://www3.telus.net/bc_triumph_registry/smoke.htm
Glenn.
1989 XJR-S 6.0.
2001 X-Type 3.0 Sport.
Both in British Racing Green.
dhdove
Smoke
Postby dhdove » Sun Nov 05, 2006 1:27 pm
Can't find any mention of mirrors on that site, wing or otherwise. Am I missing something? :?:
DH Dove
poprivet
Postby poprivet » Sun Nov 05, 2006 4:32 pm
Me thinks the author of that site has been inhaling a different kind of smoke :wink:
Pop
wolf
Many a true word...........................
Postby wolf » Fri Dec 15, 2006 10:01 pm
.............Is spoken in jest, my main engine wire harness is overloaded with smoke. I must have the optional high pressure wire harness because I couldn't believe how much smoke it leaked.
Seriously though, thats one of the funniest things i've read in ages
