4.0 litre slow tickover
millsr
Postby millsr » Tue Mar 24, 2015 4:37 pm
I have a very old S Type 4.0 litre probably the oldest on the road in the world..please prove me wrong!!
It ticks over hot at about 600 which I feel is slightly slow, can I increase it without re flash?
Does any one know a good non franchise garage in S mids that can re flash transmission for a reasonable price. Dealerships seem to want a firtune!
Re: 4.0 litre slow tickover
Postby J44EAG » Tue Mar 24, 2015 5:01 pm
You will probably find the throttle body and rotating plate on a spindle need a good clean.
Oily crankcase residue collects on the throat and plate and eventually the running air gap gets clogged and cannot pass air.
Remove the throttle air trunk jubilee clip and a small plastic nut on a bracket. Release the air box clips and lift out the air filter. If dirty change for new.
Buy some carburettor spray cleaner and wipe out the throat and plate of black congealed oil. Use only soft lint free cloth and plenty of cleaner. Take your time and don`t rub hard on the throat wall. It has a special lining material which is easily damaged. Make sure everything is spotlessly clean and that the sprung loaded plate springs back without resistance.
Reassemble and you will see a change if the plate was filthy.
Why do you think you need a reflash? Is there an issue with the gearbox and how many miles has it covered?
millsr
Postby millsr » Tue Mar 24, 2015 7:55 pm
Hi Mike, long time since we spoke!
Transmission rebuilt couple of years ago, never seems to change gear smoothly, sometimes seems to hold a long time before changing up particularly with hard acceleration . Also sometimes engages with a clunk going into D
Reg
Postby J44EAG » Tue Mar 24, 2015 10:47 pm
Hello Reg, long time old pal. Try the throttle clean out first before you do anything else. That might well make all the difference.
That done, if you think the transmission needs work, probably best to take direct to a reputable transmission restorer who will have all the appropriate kit for oil changing and a reflash. let us know what difference the throttle clean out has. It should bring the revs up. Also check to see the part throttle breather corrugated pipe attached to the trunking is clear of crud together with the fitting on the rocker cover.
Good to hear from you again Reg.
millsr
Postby millsr » Thu Mar 26, 2015 9:27 pm
Hi Mike
Removed body, it looked like new inside. Its only covered 44000 miles in 17 years, so not much use!There is, and has been for some time, a noise like a soft hiss from that area. It sounds like a leak on a suction pipe (not pressure) Most of the pipes I have looked at seem to be breathers...do you know of a pipe that sucks in that area that could affect the tickover?
Reg
ps. Is it easy to change my user name?
Postby J44EAG » Thu Mar 26, 2015 10:00 pm
Hello Reg,
Take a look at the air assisted injection valve fitted with two bolts or similar inboard of the throttle body. It is a piston type unit with two ports. The piston may be sluggish. Does the throttle plate in the body snap shut smartly if you open it?
It might also be worth checking the hot wire unit in the MAF sensor on the airflow meter just upstream from the air cleaner. Clean with spray switch cleaner or maybe replace as I did once because performance became sluggish. V6 and V8 units are the same.
Have a word with James at HQ about the user name change although PTJS1, our Paul, may also be able to help.
A slow idle is a strange one to me. Typically if it were induction leaks, the engine is likely to run faster so I`m just surmising that the air assist unit might be playing up.
millsr
Postby millsr » Tue Mar 31, 2015 9:18 am
Hi Mike
We might be getting somewhere! I have first removed all breathers and smeared a little petroleum jelly on O rings to make sure they were sealing. I looked at the air assist valve as suggested. It was not as tight as it should have been, gasket was perfect, so reassembled with a smear of jelly. Hot tick over now about 750 in P and slightly lower say 700 in D. I am happy at this so thanks for all your help once again!
One other question Mike. What is the plastic Allen grub screw for on the end of the injection valve?
Thanks for prompt reply
Reg
Postby J44EAG » Tue Mar 31, 2015 2:23 pm
A good question and nicely presented, Reg.
The hex screw can be seen in the centre of this image.
On the assumption that the screw runs in and out of the valve, I`m inclined to suggest that it is a method of fine tuning mixture control. Within the unit is a two port piston which slides back and forth in use. It may also be that the screw might also to a degree control idle speed and the piston be internally sprung. Tension on the spring might be adjusted by that screw. The amount of kit on these engines is quite daunting. I wish I knew what it is all for!
There are many pipes, tubes etc within this area. Probably best to systematically work though the whole lot and see if any nuts, bolts, clips etc, etc need a bit of a tighten up. There is also a large plastic diamond shaped plate with seals that is fitted to the inlet manifold. This could be a large source of positive or perhaps negative air leakage.
I`ve had a tired or coked MAF sensor affect running previously. That is located by four torx screws on the top of the airflow meter. Easy to remove and often the hotwire and bulb are covered in crank case residue. Use switch cleaner to remove the filth but do not poke with a screw driver! New, the unit is about £89 but secondhand I`ve bought for a fiver. V6 and V8 are both the same unit.
Hope that helps further.
