Lack of power
thomas45
Lack of power
Postby thomas45 » Fri Mar 06, 2015 10:10 pm
Well here I am again after the successful sorting of cracked cat and replaced flexi-downpipe.
All has been good for just over a week but now I find that on accelerating to climb any slight gradient I have to put the pedal to the metal and can only acheive 50mph.
Otherwise on the level speed picks up quickly without issue.
I do not know much about technical stuff but I thought that possibly a fuel system cleaning additive might help. Can anyone advise please? :?
Re: Lack of power
Postby J44EAG » Sat Mar 07, 2015 12:07 am
Mnnn...
Possible lack of speed sensor input. Needs a diagnosis.
Before that though, try a bottle of Cataclean from Halfords or other motoring outlets.
Others on this BB may be able to further advise.
oldtimer
Re: Lack of power
Postby oldtimer » Sat Mar 07, 2015 12:33 am
That's a pretty serious loss of power.
Was it performing OK prior to the cat being attended too ?
What exactly was done to the cat?
A fault of that magnitude should show upon a scan pretty quick
thomas45
Re: Lack of power all good again
Postby thomas45 » Sat Mar 07, 2015 9:59 pm
Thanks for advice, it was a bit down on power after the cat fix plus the down pipe but was picking up again for a short while. Then in the past two days very poor acceleration uphill.
No fault messages or lights, however I went to Halfords and bought 400ml of STP Complete Fuel System Cleaner-Diesel, ( they were out of Cataclean) . I then filled up and added the 400ml.
Next I took the car for a good run during which for the first two or three miles the response was not forthcoming but when I got unto a 5mile stretch of dual carriageway she suddenly took off much to my relief. So slowing down then to the legal limit and turning back I went to several of the hills that I had earlier struggled with and found she could now fly up them with no effort.
Well there it is the STP did exactly what it says on the tin (bottle)
I only have the car since late December and I think it was a problem building up to emerge eventually. I now plan to change the oil and filters but as regards the fuel filter I dont know where that item is located on this 2007 2.7 diesel.
Again thanks for all your help, much appreciated. :D
thomas45
Re: Lack of power ( more )
Postby thomas45 » Sat Mar 07, 2015 10:14 pm
I forgot to explain that prior to the work on the cat, ( as people in these parts would say ) she wouldnt pull your cap off. It was found that the cat was cracked so it was dispatched to an engineering workshop for repair and I didnt enquire as to what they actually done to it. Probably specialist welding.
oldtimer
Re: Lack of power
Postby oldtimer » Sat Mar 07, 2015 10:19 pm
I'm pleased you have resolved your problem and restored power to the required level.
I am mystified as to how a bottle of jolop can remedy a problem of the magnitude you describe.
Sadly we have absolutely no idea as to exactly what was cleared.
I'm sure you are simply relieved that the problem has been solved, it would be interesting for you to give an update in a month or so for us all to consider the result
jeff1954
Re: Lack of power
Postby jeff1954 » Sun Mar 08, 2015 4:54 pm
The fuel filter is at the top right hand side of the engine as you look in the engine bay from the front. You can't miss it as there are four hoses attached to it and it is easy to change. check on this forum on how to do it.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
thomas45
Re: Lack of power
Postby thomas45 » Sun Mar 08, 2015 8:31 pm
Thanks Jeff, I was thinking that might be it. The other issue that cleared with the STP is something I will have investigated if it occurs again. Not doing enough long runs may be to blame. :mrgreen:
