Center dash vent enhancement.......
Postby Brakebuster » Tue Jan 27, 2015 9:23 am
as we all know, the XJS has a bit of an asthmatic ventilation system , and this isn't helped by the huge vent in the middle of the dash ,
831 by MyPix on Talk Photography
it has been a known upgrade to fit the later facelift vent and or a modified one from a 40 or something, the facelift vent if you can get one is £100 or more though , so not a lot bother with carrying out this minor work
I had a slightly different idea ,
why not blank off the middle fixed section and force what little air there is to the two adjustable side vents of the outlet
with this in mind I purchased a good used centre vent for the XJS , and proceeded to chop it up :shock:
but I did have a plan , I bent some sheet tin , and formed a ' pocket ' and then covered it in period looking flock that has an adhesive backing , and ended up with this
824 by MyPix on Talk Photography
not bad if I say so myself
I then went to my car and removed my perfectly sound original vent, this is easily done by dropping the glove box door and gently prying off the walnut trim with a suitable tool , and
then removed the vent which is just a push fit
832 by MyPix on Talk Photography
and then installed my modified vent grille , and put the walnut trim back in place
833 by MyPix on Talk Photography
I still have my original vent should I wish to go back , but now have somewhere other than the ski slope to put change or keys etc , slightly too small for my iPhone though :roll:
and as for the extra air ?? , well , its a little better , lmfao :mrgreen:
poprivet
Re: Center dash vent enhancement.......
Postby poprivet » Tue Jan 27, 2015 12:07 pm
An interesting alternative. I did the Facelift vent mod many years ago as below. It does make a great difference. I seem to remember that the new vent was quite cheap, I don't know if they are still available new now though.
ng4xjs
Postby ng4xjs » Mon Feb 02, 2015 8:45 pm
I remember the exact same issue on a previous 3.6 I had. May have been wrong to do it, but I blocked off the vents to the rear passenger compartment. This gave a fairly substantial increase in air force at the front, dashboard vents.
Nick
poprivet
Postby poprivet » Mon Feb 02, 2015 10:28 pm
Yep, the favoured way is to stuff some old socks in the air duct (Washed of course :shock: )
Postby Brakebuster » Mon Feb 02, 2015 10:35 pm
i don't wear socks...............or is that pants ?
never mind , i did wot i did
BB :mrgreen:
