Almost completed the strip down for the restoration, it was very strait forward, but I need to remove the window washers to complete , so any idea's as it's not that obvius.
john
re 3.4 S type restoration
Re: re 3.4 S type restoration
good news on the strip down
afraid i know nothing of these cars, so can't help with the washers,
got any pics, as we are always interested
from a quick internet search , it looks as simple as some wing-nuts on the bottom of the windscreen washers , follow the pipework , and undo the wing-nut ?
You are correct about the wing nut,s but it looks as if either the heater radiator has to be removed or the the top of the dash , I dont wat to do either if there is a obvius way.
john
john
sorry
thought you had done a full strip down
every thing is out apart from the dash and engine!!. it is a body resto, engine is fantastic. All the interia has been removed again apart from the dash.
John
John
Top of dash is very easy to remove. Just the nuts underneath at each end and disconnect the map reading light. Can't remember though if that gives enough access to the washers as it was a long time ago that I refitted mine. Worth removing though to see.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
Mk2 3.8
Nissan Micra K13
Porsche Macan S
time for Mr Tickle arms then
