Hello all,
I am very new to all this, both owning an XJ-S and the Forum, so forgive any newbie mistakes.
The pride of my life is a 1982 V12 HE which is due for an MOT in November. I would like a localish garage to do the MOT, a major service and fix the air-con, without bankrupting me or causing damage to the Beast.
Does anyone have any suggestions or recommendations please.
Mark
1982 V12 HE aka The Beast.
Recommended garage in West Sussex
Local Garage
Markjuby
Sorry I can be of no help at all in recommending a local garage but I just wanted to take this opportunity to welcome you to the forum BB:
btw - get the garage to "Fix the air-con without bankrupting me". Ah, such innocence
Best Wishes
DH Dove
Best Wishes
DH Dove
XJS Bulletin Board Moderator
DH Dove
Thanks for the welcome, and the recognition of my "virgin" inncocence about the air con!
Since submitting this post, the following garage has been recommended. Anyone have any views:-
Godwin Jaguar
Unit 1 Philpotts Yard
Horhsam Road
Beare Green
Dorking
Surrey RH5 4QU
Mark
Jaguar XJS V12 HE 1982 aka The Beast
Godwin Jaguar
Horhsam Road
Beare Green
Dorking
Surrey RH5 4QU
Mark
Hi Mark
I'm the XJS Forum Co-ordinator and have experienced numerous failures of the aircon system over 4 XJS cars I have owned in the past and future.
Guide lines for the repair of XJS Aircon Systems:
1. Main Jaguar dealers are very, very expensive
2. Choose an independent Jaguar dealer or a specialist Air con place that knows the XJS system
3. Ask your chosen place to recharge the air con with a colored die usually yellow
4. Ask them to test for leaks in the whole system i.e
All pipes on system
Condenser by radiator
Evaporator behind dashboard
Evaporator drain tubes
Compressor
Dryer unit by radiator
5. Ask for a quote which can be reduced by fitting non boxed Jaguar parts but are to the same spec
Some people in the club are doing some of the work them selves which will be covered in a future XJS Forum article.
IMPORTANT NOTE: you must get the specialist Air con company to remove any existing gas in your system prior to working on the system
I know of independent aircon specialist in Kent who knows the XJS system very well and has worked on them for many years. Give me a ring if you need any more help on 01689 838737 see also my contact details in JEC magazine
Norman Hicks
All pipes on system
Compressor
Norman Hicks
