electric seat switch panel
agards
Postby agards » Thu Sep 07, 2006 6:02 pm
The seat adjustment switches on my 95 4.0 coupe (drivers side) pushed in and stopped working. I took the door card off to find that the plastic case which holds the switches has completely disintegrated. It seems the plastic has aged hardened and gone brittle. The microswithes mounted on a PCB still work fine but the actual swithbox itself is a write off. Can anyone tell me where I might find a replacement or help with the correct part number please?. The car doesn't have memory seats but if it's a case of droppiing a memory seat version of the switch onto the same connector then that would be even better
agards
Postby agards » Fri Sep 15, 2006 10:59 am
sorted now thanks to a great service from Grublogger
