Following a recent post on the Mk2 BB and my own need for a 360 degree engine building cradle, I am about to purchased a suitable unit.
Rated at 1000lbs or 450kg this unit mounted on castors should meet my requirement. At just under £42 delivered from ebay, I can no longer justify not having such a piece of equipment. No more crawling around on my hands and knees trying to turn over a heavy old engine on a concrete floor! It will be nice to be able to stand whilst popping pistons and rods into an engine and then to be able to flip the engine over to drop in a crank. That will certainly help my worn out back.
http://www.ebay.co.uk/itm/1000lbs-450kg ... 2423&rt=nc
For interest, a fully dressed AJV8 engine weighs around 440lbs or 200Kg, so this engine stand is more than capable of safely supporting the load.
Once again long live the Chinese tool revolution.
AJV8 engine weight and suitable engine building cradle.
jonjeffryes
Re: AJV8 engine weight and suitable engine building cradle.
That's a great result Mike.
In the end I bought this unit. A humble £2 or so cheaper. Martec and I are rivals in the tight git competition!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1440304779
A good job it folds up. My space availability now becoming critical again. Better buy another boat as another junk store.
jonjeffryes
Nice bit of kit mike....I don't actually need one but feel strangely compelled to by one for the man cave!
Sorry Mike you lose,
I modified the cradle I made for the XK engine.............total cost S@d all.
I hope you are better now and had a good Christmas, I'll say nothing about New year as I'm sure will know how to celebrate it.
Best wishes
Best wishes
Martec wins by continued default! As usual!!
The stand arrived here as I arrived back from Christmas. UPS in my opinion provide a wonderful service. Shame that other company went through the hoop recently. I`m amazed these logistics companies make any money at all. Vehicle running costs, staff and facilities etc. I suppose ebay must account for a fair amount of their business.
The typical cheap, crude, cheerful and adequate industrial build. Red steelwork, Victorian castors and wheels and a simple drop in pin through several equally spaced holes drilled through frame and swivel mount. A handle helps control out of balance rotation as an engine is turned over when you work on it. Obviously one would aim to have the engine weight in equilibrium as far as possible which is down to careful rigging of an engine block to the swivel head arrangement. At £38 including delivery, you can`t really go wrong.
Thanks for your wishes, Brian. back somewhat improved but the nerve is still trapped which continues to make standing or walking on my right foot most uncomfortable and fatiguing.
Cheers Guys. Happy New Year.
Mike,
I like the bit, and flip it over and pop the crankshaft in. I struggled to lift an XK crank all those years ago so wouldn't attempt it now.
Happy new year to you all
Phil
Phil
