Change spark plugs on 3litre v6 1999-2000
hi could any body give me any information on how i change spark plugs on my 3 litre v6, any diagrams or specific info on whats involved or tools needed would be appreciated. thanks, jim
Re: Change spark plugs on 3litre v6 1999-2000
Try this link, Jim.
http://www.jec.org.uk/forums/viewtopic.php?f=193&t=7225
This link has general specs for your car and may be useful.
http://www.jec.org.uk/forums/viewtopic.php?f=10&t=8633
Note that tired plugs if left unattended cause misfires which usually leads to individual plug on coil failure.
Fit long life plugs as the inlet manifold has to come off to do the job and you don`t want to have to do that very often. Note the remarks about the air elbow pipes which collapse and rot over time. Not expensive but only available from a Main Dealer. Have these elbows to hand before you start the job.
Let us know if we can be of further help but in the meantime take a general look at posts within the sections of our Bulletin Board. You will see we have got to know this car well over the years.
thanks very much mike. require information on removing inlet manifold prior to changing the plugs etc, and anything else involved. thanks again for your help, jim
jonjeffryes
I've just removed my intake manifold for the second time this month...no I didn't follow Mike's advice and changed the plugs but not the rubber elbows the first time around!
I would recommend that you purchase intake seals; upper and lower; if you are replacing the lower elbow and removing the fuel rail, injectors and lower intake....before you take things apart.
Also whilst you have the intake manifold off, I'd recommend that you change the two seals on the intake variable valve vanes (the two round black housings bolted to the top and back of the manifold).
Take care when removing the manifold - there are different length bolts so keep them in the correct order. Also if you are removing the fuel rail, take care with the upper injector seals as the are easily damaged or lost and Jaguar only sell complete injectors.
One of the bolts had been over tightened on my car so the insert in the lower manifold just span around (the insert is metal and the manifold plastic) requiring a good deal of bodgery and a replacement lower manifold.
Be very careful when removing the expansion tank water hose from the top hose - the plastic connection is very easy to break off!!! A replacement part is £48 new on EBAY.
Finally, as you have the inlet manifold off, check all of the vacuum lines and the rubber connectors and replace as appropriate. All of the rubber connectors on my car had hardened and cracked with age.
Hope this helps
Jon
Hope this helps
Jon
thank you for the info jon really helpful
