MAF sensor. Supplier and part.
Postby J44EAG » Sat Oct 25, 2014 6:18 pm
This sensor fits all models and years. Indeed I have fitted one from a V6 to a V8 without issues. Before I changed the sensor, idle was rough and performance lacking.
Before replacing, remove from airflow meter (four Torx screws)and clean the hot wire of crank case breather residue with spray switch cleaner. Don`t touch or pole the hotwire about. It is very delicate. If that makes no difference, clean out the throttle body throat and throttle plate with carb cleaner and soft rag. if neither action helps, a new sensor may be required and can be confirmed by a diagnostic interrogation which might say the sensor is out of limits. I replaced mine at 75k miles. Luckily I found an almost new one on a V6 in a breakers yard which came to me for a humble fiver.
Should you need a new replacement unit, this one is offered on ebay for £49.99 with the option to make an offer. Fitment takes only a couple of minutes and access is easy.
http://www.ebay.co.uk/itm/NEW-Air-flow- ... 336fc36c7b
