Steering wheel swap, X350 > X308 ?
Moderators:robv12, DavidEm
XJ_Driver
Postby XJ_Driver » Sun Oct 19, 2014 9:02 pm
The steering wheel on my recently acquired '99 X308 is looking shabby (suspect the previous owner wore a large / heavy ring). I found a replacement wheel at Stoneleigh last weekend, but upon getting it home realised that it is for an X350. Looking at the two wheels side by side they appear the same size & shape, but does anybody know whether the splines are the same or different? Assuming the new wheel will fit, any other reason why it might not be compatible with an X308?
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
robv12
Re: Steering wheel swap, X350 > X308 ?
Postby robv12 » Mon Oct 20, 2014 10:53 am
it may well fit, but will the airbag fit as well??, and, is the 350 airbag cassette in the wheel the same, I think not, you will also have issues with the cruise and other various steering wheel mounted controls imo
sounds an improbable swap to me,
let is know how you get on
and, be very careful when playing with airbags, the are essentially small bombs and WILL hurt if the go off
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
