this time behind the windscreen washer bottle under the offside headlight, the washer bottle mounting bolts can be seen in the white section in the top of the picture,
if you have never taken out the water bottle , this could be what is waiting for you , i was gob-smacked when i saw it, but see how good the metal is behind the holes in the subframe, all they needed to do was put a little corrosion protection in there....
http://gallery.talkphotography.co.uk/da ... edium_.JPG
made a template from card , and cut out some sheet metal , folded and fettled to shape, as it isnt at all flat !!
offered up for test fitting prior to tack welding ,
then fully welded , as it forms part of the inner arch, but not fully structural , also spot welded the edges i could get to
then the welds were sealed with flexable joint sealer ( that will never fully set ) and then coverd in underseal , forgot to say , high zinc content paint was leberally aplied to the repair as well,
similar story on the nearside, but not so drastic
yet more rust beaten into submission
Body Repairs
At this rate you'll be on the road in a couple of weeks!
All The Best, Hope to see you soon
DH Dove
DH Dove
XJS Bulletin Board Moderator
