S-type suspension replacement/renewal
johnnewzealand
Postby johnnewzealand » Wed Sep 10, 2014 5:40 am
Hi.
2001 3L petrol. Now done 240,000kms., trouble free, serviced every 16,000kms. at Jaguar agency. No problems, but have decided to keep really long term as I love it so much - don't like the XF !!!
Front shocks have been replaced, and front anti-roll bar bushes replaced, around 150,000kms., and a rear wheel bearing around same mileage. No other suspension work been done as none deemed necessary at the regular services.
Lately, have noticed a slight "creaking", at low speeds when turning over bumps, and seems to be from the back. After cleaning the car - underneath as well, it seems to go, but soon returns. This only when turning, at low speeds.
Any thoughts on suspension bush renewal?
As said, am keeping car long term, so thinking of having all suspension bushes renewed, and perhaps wheel bearings. Should I have this done, or wait till the Jag. agency say they need doing? The "creaking" is a bit annoying though!
johnnewzealand
Re: S-type suspension replacement/renewal
Postby Brakebuster » Wed Sep 10, 2014 7:12 am
sounds like rear anti roll bar bushes, and possibly the links to
these are usually the first to go , but it does depend on driving style and the general condition of the roads
that would be the first place to look, and the cheapest ,
Postby J44EAG » Wed Sep 10, 2014 4:08 pm
Hello John.
I would suggest lower rear wishbone bushes as creaker parts. Typically they creak when turning.
To save me writing what I`ve already covered several times on the subject of wishbones, vertical legs, hub carriers, radius rods, wheel bearings and ball joints, I`ll point you towards our suspension section which has many detailed posts on the subject. In many cases I have included photographs of work in progress and how to source the best parts price deals. (usually via ebay}
http://www.jec.org.uk/forums/viewforum.php?f=200
This is the direct link to the suspension section and covers most common issues to be found with aged S-types.
I have run an S-type for around 9 years now. I can draw the suspension of one in my sleep! This year I have had to undertake extensive suspension work. Again photographs, comment from others and pictures show the work as it progressed.
http://www.jec.org.uk/forums/viewtopic.php?f=200&t=8040
Please feel free to ask us questions and we will do our best to help you.
Mike Kennedy. Former S-type Forum Co-ordinator.
johnnewzealand
Postby johnnewzealand » Thu Sep 11, 2014 7:52 am
Thanks Mike & BB,
much appreciated.
Your knowledge, and articles, very valuable Mike, and very interesting.
Wish I was a bit younger to tackle the work myself, but now have to rely on Jaguar Agency to inform me of what needs doing! Unfortunately I seem to have to "tell" them in some cases! Examples are, .. coolant flushing/replacement every two years, brake fluid replacement every two years, AND, very importantly, auto trans fluid/filter changes (every 30,000kms.). Regarding the auto-trans, even the Jaguar agency say it is a "sealed for life" item! Possibly "Jaguar" at fault re this issue, as you and I know, fluid and filter "should" be changed as a routine.
Anyway, re my suspension queries, will ask for specific suspension items to be replaced, and of course full suspension "bushes" etc. be fully checked regarding vehicle mileage.
Thanks guys, johnnewzealand.
johnnewzealand
Postby J44EAG » Thu Sep 11, 2014 11:00 am
Our pleasure, John.
You seem to have an understanding of the car which is good.
The transmission oil needs to be the right type. Jaguar part number is JLM-21044. Products to the equivalent spec may be used which includes Mercon V.
Your car is fitted with the Ford Bordeaux derived 5R55N transmission. This is "filled for life" rather than "sealed for life". The wording and inference is very different. Reference to the car handbook also states that fluid should be changed if the car is operated under "heavy duty" conditions. It does not state what constitutes heavy duty use. Experience has taught us that transmission oil changing will help the transmission survive longer. Note that a full oil change requires specialist equipment which changes sump oil AND fluid contained in the torque converter and oil cooler. Just changing sump oil does not constitute a full oil change. The sump filter on the 5R55N can be cleaned and reused. The later six speed ZF unit requires and complete sealed sump and filter to be replaced as it cannot be cleaned out.
The gearbox CAN be refilled via the breather on the top of the transmission case. It is essential that when obtaining the correct level, the car have the rear wheels off a ramp to enable in gear topping up and total oil distribution and that the transmission not be allowed to exceed a certain temperature. The car should be plugged into a diagnostic computer to allow that temperature to be monitored.
Old transmission oil when drained should be in clean condition when drained. Experience tells us that yellow or brown colour is acceptable. Black oil indicates a very worn transmission and refilling with new oil is likely to be unproductive as new oil detergent effects dislodge particulate within the gearbox and will almost certainly cause the electric gear change solenoids to become quickly blocked with particulate and sludge. So oil changing is worth doing on gearboxes in good condition but benefits on old worn units may cause more issues than it solves. Further discussion on Jaguar oil changing and associated issues are well documented in the transmission sections of our S-type, X308 and XK8 Bulletin Boards on this site.
Upper wishbones front and back, lower front wishbones, arb vertical links, rear radius rods and anti roll bar bush or damper and spring work rectification is fairly straight forward. Most knowledgeable individuals and garages car attempt and succeed with repairs to these areas of the car with relative ease.
As far as lower rear wishbone bush changing, the front vertical leg/hub carrier wheel bearing cartridges and the lower front ball joints or damper bush replacements, these are rather more specialist in requirements.
Rear wishbone bushes can be changed reasonably easily but a good bush tool replacement kit is required. In most instances the use of a bench press is not required.
The front vertical leg and wheel bearing carrier and ball joint are well neigh impossible to tackle without a bench press. Seizure of the steel bearing cartridge to the alloy leg is common due to mixed metal galvanic action. Most bearings require force to be applied via the bench press to remove the cartridge. The last one I removed required nearly 4 tons of pressure to be applied before it let go! Note the cartridge most be removed before the lower ball joint can be replaced.
On MY99-02 model cars, to replace a lower ball joint, the bearing cartridge is removed to gain access. The joint removal process has most operators running scared for fear of breaking the leg in the process. In my experience those fears are completely unfounded. The joint does not need much pressure to remove but the leg must be correctly and carefully supported. I cut off the threaded portion of the joint, place a spark pug socket on the remaining ball, chock the leg up and apply bench press pressure. The remains of the ball joint then push out easily. Fitting a new joint requires care and a couple of large cut down large sockets or short pieces of appropriately sized steel tube. Inverted, new joint is placed in its register having been carefully blocked on a press bed. Using other sockets and tubes the leg may gently be pressed down onto the new ball joint until fully home. That done, a serviceable wheel bearing cartridge or as I would recommend a new unit be fitted. With the dust shield refitted to the leg, the leg can be refitted to the car.
Post MY 02 cars have a slightly different lower front ball joint and wishbone drop arm arrangement. The ball joint is inverted in the vertical leg/wheel bearing carrier. This allows for slightly easier replacement. However, the wheel bearing cartridge still needs to be removed to gain working space.
With the right equipment, servicing the suspension on S-type, X350 or XF models need be that difficult. Forget it if the right tooling is not available!
