UNF/UNC? What's right for XJS nuts/bolts?
So, I'm after a few nice stainless nuts and bolts to tidy up my engine bay. What should I be buying? Found out the hardway all of my stainless metric nuts are useless
Re: UNF/UNC? What's right for XJS nuts/bolts?
The basic issue is that the car was in continuous production for 21 years so there's all sorts on it! don't give up on your metric set - there will be some of the newer components that will be metric.
Most are a mixture of UNF and UNC.
Sorry - there's not a clear answer to this one!
XJR-S,
As David has said, your car is a mixture of standards. So, you'll definitely need some metric for some of the under-bonnet replacements.
Every time I take off a non-load bearing nut, I try and replace it with stainless. I am for ever having to check thread pitch etc to know which standard to use.
Thanks! That's a pig isn't it
Hey ho!
Much appreciated.
Much appreciated.
