Auto Delay Lights
petergl1800
Auto Delay Lights
Postby petergl1800 » Sat May 24, 2014 7:04 pm
I have just started to have a message come up saying my 'Delay Auto lights' has switched itself off!
Can this be re-started?
Re: Auto Delay Lights
Postby J44EAG » Sat May 24, 2014 9:05 pm
I have an earlier car, Peter so can only advise from my own experience.
My car has the manual rotary switch to operate lights manually. However turning the switch anticlockwise through the off position gives you the option to have lights come on as ambient light reduces at dusk. Turning the rotary switch further anticlockwise gives a longer period before the lights switch off depending on where you set it. The idea is to allow you to walk from the car to your front door in a preset time. This can be varied at will to cater for a long or short walk before the headlights time out.
May be you have the light switch set to the off position presently?
