Loss of coolant
Moderator:jBlackwell
vernon
Loss of coolant
Postby vernon » Fri May 16, 2014 2:07 pm
just as every thing was going well my car dumped most of its coolant on the garage floor.
We had just parked with a hot engine and the bottom radiator hose blew a hole in its self.
The car does not overheat, but I am told this was caused by heat soak.
Does anyone know where to get replacement mk3 4.2 hoses? (Not silicon) all the places I've tried only supply a kit of hoses I don't want.
Vernon
Nostalgia Classic 120
Modern S type jag
lowebird
Re: Loss of coolant
Postby lowebird » Fri May 16, 2014 7:13 pm
Vernon,
When I needed a replacement top hose, I got a Ford right angle bend and cut it to fit, perhaps you could try something like that, otherwise, why not contact the factory to see what they use.
Reg
vernon
Re: Loss of coolant
Postby vernon » Sat May 17, 2014 9:59 am
Thanks reg,
I have found a set of hoses for a series 3 4.2xk engine from SNG Barrett at a reasonable price, it does not have to many unwanted hoses.
I did find individual hoses available in America, but they would have cost more than the set.
Thanks for the info.
Vernon.
Vernon
Modern S type jag
NATONEIL
Re: Loss of coolant
Postby NATONEIL » Sat May 24, 2014 10:21 am
Reg
What was the part No for your top hose? because I want to replace mine
Neil
Suffolk SS100 Jaguar
Honour the past, drive it today
lowebird
Re: Loss of coolant
Postby lowebird » Sat May 24, 2014 1:21 pm
Hello Neil,
The details shown on the hose are as follows:-
GATES 7033ES
You have to cut quite a lot off each end but the angle seems o.k
I got mine direct from the SS factory however I expect a Ford dealership will stock them.
Good luck,
Reg
