Steering Column Removal
Moderator:MSB
steyning25
Currently in the process of removing the body shell to facilitate refurbishment and repainting. The rear end is corroded and will need replacement. Reading through the service manual there appears to be no instruction on how to remove the steering column on XK120- any advice please.
Re: Steering Column Removal
If you are still in need of help, I have a copy of the full workshop manual for the XK120, which I feel sure will detail exactly the process. I am not at home until Monday, 19th May, but will gladly forward the detailed guide to you on Monday, if you get back to me by then. David.
