Hi, Anyone able to confirm the "nuts & bolts" used on 68 2+2. I believe they are AF but wanted to check prior to ordering assorted nuts bolts etc. Seems previous interactions with the car have involved fitting whatever was at hand.
Anyone recommend a supplier for nuts and bolts?
Kevin
nuts and bolts
Re: nuts and bolts
Hello Kevin,
although often referred to and a basis of spanner size(both Imperial and Metric), AF is not a fastener type.
You need largely UNF with some UNC fasteners (UNC typically for studs that go onto tapped holes)
I can recommend a company called Namrick (www.namrick.co.uk) which stocks a large range and caters for the car trade. While stainless steel is popular as a replacement do not use them on safety critical assemblies as they are not as strong as the usual high tensile mild steel fasteners, e.g. suspension or brakes.
Hope this helps?
Hope this helps?
