Gearbox oil change?
Moderator:cawthrm
KevNoble
Gearbox oil change?
Postby KevNoble » Fri Apr 04, 2014 5:39 pm
Hi. I have just bought an XF 3.0D with 93000 miles on it. I used to own an X308 on which the gearbox failed at 100k miles, so my question is: should I have the gearbox oil and filter changed? (Bristol Transmissions did an excellent job fixing my X308 gearbox, but I wish to avoid that this time). Many thanks
First Jag was an LPG X308 XJ8; now have an XF 3.0D. I enjoy doing my own maintenance.
raysearles
Re: Gearbox oil change?
Postby raysearles » Sat Apr 05, 2014 11:12 am
Modern Jaguars are in theory, filled for life. But there are many tales and well documented threads in both the XJ and the S Type forums that demonstrate that gearbox problems will occur if the oil and filters are not changed around the 100k mark.
It is important to take the car to a garage that actually flushes out the old oil, as opposed to just draining it, to ensure you get all the rubbish and gunge out.
I shall be taking my XF to have its g/box oil changed at around 90-100k miles; the cost of the change relative to a new gearbox seems a small price to pay.
This is a question that I shall pose to XJK at next weeks seminar to get their opinion.
Hope this helps
Ray
Ray
JEC Events Chairman
1999 XKR Convertible (K8)
KevNoble
Postby KevNoble » Sat Apr 05, 2014 7:48 pm
Thanks for that - it confirms my opinion, especially having been "bitten" once already! I expect to be working on the 12th, so I can't make the XF symposium, otherwise I'd have been there. Kev
