Oil Grade for a 5.3 V12?
XJR-S
Postby XJR-S » Thu Mar 13, 2014 2:48 pm
For all intents and purpose my 6.0 XJR-S is really a 5.3 with some frilly bits. So what oil should I be running? There's a wide band of grades in the book for the kind of UK temperatures we have, and it's currently done only a few miles on shell helix ultra 5w40, which isn't the right grade for this country's weather from what the manual says so I want to change it now.
Should the oil be fully synthetic I assume? I mainly ask as I keep a very big stock of 10w40 semi synthetic for my two other cars which I change regularly, and being lazy, would like to use the same, but only want to use the best for the car.
Re: Oil Grade for a 5.3 V12?
Postby davidr » Thu Mar 13, 2014 3:36 pm
I take the view that the basic engine is quite old and designed decades before some of these fancier oils were thought of so I just use a semi-synthetic 20/50. A thinner grade like 10/40 just encourages the leaks!
I also change it frequently.
regards
David
steve_m
Postby steve_m » Thu Mar 13, 2014 11:08 pm
Try the following link.
It doesn't specify a particular one for your model but it does suggest that you call their technical helpline; let me know what they say as I want to change mine soon!
http://www.morrislubricants.co.uk/lubri ... efault.asp
PaulGover
Postby PaulGover » Fri Mar 14, 2014 12:53 am
I've been using Morris's 10W 50 semi synthetic very satisfactorily in my 1991 5.3; doesn't consume much between changes, stays pretty clean for much longer than the old organic oils.
Reg
Postby Reg » Fri Mar 14, 2014 10:40 am
I always use mineral oil...20/50...as I read synthetic can cause seal leaks, I don't know about semi-synthetic..
oldtimer
Postby oldtimer » Fri Mar 14, 2014 10:41 pm
I use 20/50 mineral oil - have done for years.
They used to say, If a Jaguar has no oil leaks it has no oil !
XJR-S
Postby XJR-S » Sat Mar 15, 2014 2:45 am
Excellent thanks all!
I've just noticed how my XJR-S Supplement oil page varies from the standard book page. "Due to the high performance capability of the 6.0 litre V12 engine, Jaguar recommended that a suitable high performance synthetic engine oil which meets the specification requirements shown below should be used at all times..."
They recommend Castrol 5w50 or 10w60, as well as the standard oil chart that you probably all have. I'm probably going to have a go with the latter! Interesting as I wouldn't have thought there was that much difference.
poprivet
Postby poprivet » Sat May 31, 2014 1:11 pm
Was looking in Wilco this morning. 5l containers of semi-synth 10/40 and 15/40 for £15. Fully Synth for £20
'Own brand', but It meets all the standards, Unless someone tells me its rubbish I think its worth a punt?
BigCatXJS
Postby BigCatXJS » Sun Jun 01, 2014 5:36 pm
I have run with semi-synthetic and more recently, fully synthetic (Comma X-Flow Type G Fully Synthetic 5W40). I would agree that fully synthetic encourages more leaks so make sure that you don't have too many :D Some slight leakage is fine as this is my sub-frame rust prevention system :D
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
