Early 4 ltr engine with 'ticking' timing chains!!!!
Martec
Postby Martec » Wed Mar 12, 2014 6:02 pm
I've been asked to have a look and listen to a MY1999 4 ltr S type, It went to a local independent Jaguar repairer who found the top tensioners broken up and the top chain 'worn' they replaced the tensioners and when the noise hadn't disappeared they asked if the owner wanted the chains replaced???
The noise only occurs once the engine is warmed up, not when cold???
I know nothing of the 4 ltr engine, any suggestions as to what to look for please. I'm taking my boroscope in case we delve deeper.
Re: Early 4 ltr engine with 'ticking' timing chains!!!!
Postby J44EAG » Wed Mar 12, 2014 7:20 pm
Hello Brian.
I wonder if this noise might be worn VVT units? Some small chance.
I further wonder what series of tensioners were changed and whether the ali 4.2 units were built onto the engine. Any idea of subsiquent mileage covered? Here is an image of the ali type.
Image here shows two original plastic units taken from my engine at only 44k miles. Note the split bodies. The third tensioner was from my Black Museum and is a nasty case. Bottom of the tensioner missing and the top slipper plate torn off by the chain. If the garage were inept enough not to change worn secondary chains, then it could be the new tensioners have been damaged along the lines of this third sad unit.
There is loads of information on our BB sections about tensioner issues. XK8 and X308 Boards make good reading. However the best reference source comes from our old friend Brake Buster who contributed amost graph piece on tensioner replacement. The text was later revised and made great copy in one of our magazines a couple of years ago. Highly recommended reading. Go to "I changed my tensioners yesterday" on the X308 Bb for this gem of information.
There could also at high mileage be a primary guide plate problem. They do develop cracks as seen in this next image. I`ve not heard of any complete failure yet though.
Cracked V8 primary chain guide 162k miles.jpg (53.77KiB)Viewed 4913 times
This third image is of a partially stripped V8 and shows the general arrangement.
Try these leads to start. No doubt some of the other guys here will also be along soon to add their wisdom to this post.
Martec
Postby Martec » Thu Mar 13, 2014 12:35 pm
Thanks for replying Mike, I've just made another collar and fitted it for the exhaust pipe, so a bit knackered.
The tensioners look horrendous, but these were changed 6 month ago and I don't know mileage since or total mileage. I report back after a look this afternoon.
Martec
Postby Martec » Thu Mar 13, 2014 6:00 pm
An Update,
The car was cheap and bought with this fault, given to the local Jaguar specialist and after £500 it still had the fault. This was much less than 6 months ago. The car has 97,000 miles on the clock, main agent serviced for 10 years and probably not after that as the oil was recorded as like tar.
The engine is relatively quiet on start up but becomes almost quiet after 5 minutes, but after a short run around the village it sounds like a bag of spanners. We think the noise is coming from the top end front passenger side tappet area. So Philip will take the cover off for us to have a look. The drivers side back of cylinders sounds as it should, I seem to remember you took the cam cover off some years ago Mike.
We are thinking coil pack and plug? worn cam lobe, blocked oil gallery, worn tappet shim.
The car hasn't been looked after as the central locking doesn't work (been here before) knocks from the suspension, and pulling to one side (been here as well).
I'm looking forward to seeing the cam covers off the engine (am I sad?)
Postby J44EAG » Thu Mar 13, 2014 8:07 pm
I`ve never had to go that deep, Brian. Spark plug covers only for me. New tensioners were fitted by my garage in the days when I could afford to have the car looked after professionally!
My suspect is a tired or clogged VVT unit. Plenty of good second hand ones around on ebay if required. Also try Auto reserve parts. Great gut by the name of Andy. He breaks nothing but modern Jags.
Taking the NS spark plug and cam covers off is likely to be a bit of a pain on the V8. The NS bank at the back is well buried into the bulk head area. Hope you have long thin arms and hands!
oldtimer
Postby oldtimer » Thu Mar 13, 2014 10:07 pm
Hi Mike / Brian,
The start of another interesting saga.
Interesting that you say the oil resembled liquid tar. I've read on here or somewhere how important clean oil is for functioning of the VVT.
Do you have a stethoscope with a metallic probe - (an upmarket screwdriver) sometimes quite revealing as to where noises are coming from.
On the basis that shim pads have remained the same over the past 100 years, well since 1948, then they do not wear, although the tip of the valve stem does impact into the shim leaving a corresponding indent. I guess this will nominally increase tappet clearance.
Getting involved in a job down the line is a problem in that a lot of the history is lost. Like, where has the chain tensioner debris gone! I do find it disappointing that with a mileage of 97K miles that the chains were not changed whilst doing the tensioners
As usual - keep us up to date
Oldtimer
Postby J44EAG » Fri Mar 14, 2014 1:45 pm
Another thing to check, Brian.
See my recent post about the issue that cropped up with the V8 upper idler pulley on my car. That was making some odd noises and investigation revealed the pulley moving around on its mount. A simple no cost fix on that occasion.
You noted the reference about the V8 you are involved with regarding the previously noted treacle like oil quality. The VVT units need oil pressure to operate and sludged oil is likely to impact on their operation. I think I would be inclined to oil change with some cheap oil and add a flushing additive. This would help break down any sludge deposits which may be blocking up vital components within the engine. Most of these additives have instructions to run the engine for twenty minutes or so before draining oil and refilling with the correct lubricant. Just and idea that might prove effective.
Phil notes that broken tensioner parts have to go somewhere when they fail. The failed tensioner shown in my earlier post deposited the lower foot and upper slipper plate in the engine sump. Obviously it is undesirable that it remain in that location.
As regards old type and new ali tensioners, note the fitting bolts for the later type have a different length to the earlier type. It could be possible that the new tensioners are loose on their mountings.
Martec
Postby Martec » Sun Mar 16, 2014 10:36 am
Thanks guys, all good stuff to check.
We used a big screwdriver to try and locate the noise better hence the top of the passenger side front cylinder, but as I know from my own engine big end it is difficult to pin down without internal investigation, and it looks a nightmare to get at. Philip has replaced the tensioners on their XK8 and bought rather than borrow the timing kit, so is not concerned on that score.
I thought about your loose pulley but forgot to check that, As these engines don't have hydraulic tappets I did wonder about tappet gaps and worn /broken up shims and were the broken bits of tensioner had gone.
Unfortunately it is now in the realms of 'if its costly to fix it will be sold off as bits', they run a business after all. If it does go I've asked for first pick of the bits, but hopefully it won't come to that.
Postby Brakebuster » Sun Mar 16, 2014 1:29 pm
there was an issue with the cam bolts becoming loose over time, and can cause a tick where the cam is effectively jumping around ,
easy to check , just run the torque wrench down all the cam bolts ,
if this is the issue , power should also come up when fixed , as the timing will be more accurate
good luck
Martec
Postby Martec » Sat Mar 29, 2014 5:29 pm
We called in to see Philip today and I parked our S type next to his in the hope that good vibs would rub off.......I know daft or what!
But Philip has found the problem, he had some fun getting the cam cover off and it looks like the black dead of old in there, but also as the engine is turned over with a spanner the top timing chain is tightening on the top and then on the bottom! The brand new metal tensioner is not taking up the slack as there is toooooo much of it. Plus I could push the tensioner pad and chain down and it would spring back up until the chain was turned a bit further and the exhaust cam pulled the chain tight and there was then a massive amount of slack at the bottom.
I think there is so much slack in the chain that the ratchet in the tensioner didn't make contact and is now smashed. If the inlet cam is turned to show the flat on top the exhaust cam is way off.
Only the passenger side bank is so bad, so he is going to replace the chain and probably the tensioner and repair the rotten drivers side sill and keep it (at present). He has come around to the charms of the S type!!
Even if it is a V8.
PS another for the V8 rogues gallery!!
Postby J44EAG » Sat Mar 29, 2014 5:47 pm
Agree with you fully, Brian. In a V8 you can be really bad. Join the power oversteer club like me! Opposite lock just going to the shops!!
Has the tensioner been put in upside down?
oldtimer
Postby oldtimer » Sat Mar 29, 2014 10:46 pm
Mike / Brian,
I guess I'm kidding myself but should there not be some liability in respect to the garage job???
P
Martec
Postby Martec » Sun Mar 30, 2014 5:36 pm
Hi Mike and Oldtimer,
I thought you had cracked it there Mike, but I've drawn out the chains and the chain tensioners, they are the right way around as I see they are one way up for one bank and upside down for the other.
Philip has done the tensioners on their XK8 and XKR (4 ltr) and says the top chain is very worn.
It is good he has found the problem and I was glad to see it rather than be told of it. At least it should (I hate that work) be a cheap fix, if as Brake Buster was suggesting it would be another head or scrap.
The car was bought with problems and given to this independent garage who after finding the noise was still there then wanted to go back in to replace the chains. The owner drove it for 6 months and then Philip got it very cheap. Its all second hand talk now, so I suspect too far away on time alone for a claim. It is really a bit of a hack with engine noise, none locking doors (another broken wire or lock micro switch) noisy suspension and rotten sill. It will be lucky to survive, a pity as with a bit of TLC it could be nice again. I suppose it is in banger status now.
Postby J44EAG » Sun Mar 30, 2014 6:21 pm
A shame. Every dog has its day.
If it is to be broken, I could do with a lower front o/s corrosion free brake pipe. Thats the one that comes out of the ABS block, dives down and runs along the O/S chassis leg above the engine mount and is fixed with a clip to the body. Brake pipe only available by the roll from Jaguar!
That car could be a little gold mine in parts. Sadly I don`t have any space here to store a good scrapper.
Very rare to see a rotten sill on an S-type. Most shells go to Heaven with bodies in very solid condition.
Martec
Postby Martec » Mon Apr 28, 2014 8:36 pm
Philip finally got hold of a pair of split link top chains from Annie Jenkins and reused the new metal chain dampers and all the camshafts are back in there correct timing.
I'm told it sounds very sweet and he is moving onto sill repairs, someone 'says' they want to buy it. I don't think Philip would be sad if it stayed with them.
The noisy suspension was just the front anti-roll bar drop links, so that is a cheap one.
