VSE engines
Pierre19
VSE engines
Postby Pierre19 » Thu Dec 05, 2013 12:09 pm
Hello,
I'm french member.
My XJC 4.2 makes a strange noise and i'd like to offer it a good engine rebuilt.
Can you tell me what to think about VSE engine ?
Can I send them the engine from France without fears ?
Thank you for yor help
Pierre
aramco62630
Re: VSE engines
Postby aramco62630 » Fri Dec 06, 2013 3:13 pm
Hi Pierre.
Re your enquiry about VSE engines. You can have every confidence in VSE. They've been dealing in and building XK engines for years and are very professional.
Best wishes.
John.
Pierre19
Re: VSE engines
Postby Pierre19 » Sat Dec 07, 2013 8:34 am
Thank you for your answer :)
lowebird
Re: VSE engines
Postby lowebird » Sat Dec 07, 2013 12:02 pm
Bonjour Pierre,
Yes, you can use VSE with complete confidence, I have an XK 4.2 engine which was rebuilt by them, in my Suffolk SS100 and it runs really well and sounds great. The web site is:-
www.vse-engines.com.
Reg
Pierre19
Re: VSE engines
Postby Pierre19 » Sat Dec 07, 2013 4:14 pm
Merci :)
Pierre19
Re: VSE engines
Postby Pierre19 » Thu Sep 11, 2014 7:20 pm
My engine came back from VSE in july.
I hope to finish the car before the summer... The body needed more work we thought.
ecosselynx
Re: VSE engines
Postby ecosselynx » Thu Sep 11, 2014 8:53 pm
Hi Pierre
Had my engine rebuilt by VSE in 99/2000, done approximately 40k miles since then. uses about a pint of oil every 1,000 miles. When real hot after a day running it has 45 psi oil pressure at idle.
Go for it.
John
bye-o
John H.
