heater valve
stiky
heater valve
Postby stiky » Wed Nov 20, 2013 4:24 pm
Hi i am looking for a vacuum operated heater valve for a 1967 S Type S N G do not do these valves anymore however they have give me a part no JLM 1311 which is the new part no for a replacement valve can anyone shed some light on this valve or were to buy it.
cheers jim
macdonjc
Re: heater valve
Postby macdonjc » Wed Nov 20, 2013 10:05 pm
I would suggest setting up an ebay search. It is amazing what turns up there. Also have you checked with the JEC technical adviser for that model? Good luck!
jackois
Re: heater valve
Postby jackois » Fri Nov 22, 2013 7:03 pm
Hi there, if you can't find an original, I fitted a vacuum valve made for an american Ford.
All the details are on the following post... perfect fit and works as per the original.
http://www.jec.org.uk/forums/viewtopic.php?f=119&t=6694 is the web address for the post.
Hope this helps.
Peter
stiky
Re: heater valve
Postby stiky » Mon Nov 25, 2013 4:19 pm
Thanks every one for all the info managed to get a second hand one from e bay that came off a porsche it arrived to day fitted and working fine. :P
