Boot trim
eugos
Boot trim
Postby eugos » Tue Jun 04, 2013 9:00 pm
Can anybody help me, I have a 53 Coupe, and I am in the process of a rolling restoration, the carpeted trim panel in the boot that covers the fuel tank has bowed and falls down into the boot.
I suspect that there should be a panel to hold it in place that would fit inside the boot underneath the parcel shelf, can anybody advise as to weather that is in fact the case or is this a common problem.
Attempts to glue it in place have failed, any advice would be appreciated, especially the part no if such a panel exists
Eugene
Re: Boot trim
Postby mike020150 » Tue Jul 23, 2013 10:30 am
No longer running the earlier model means I can't just pop into the garage to check but from memory, the luggage compartment front panel is a single piece of trim that is only held in position by its moulded shape and the side liner trims (it tucks behind the latter). Mike.
