drilled a hole through my thumb !!!
Postby Brakebuster » Sat May 04, 2013 10:19 am
I know DIY in the home can be dangerous , but working on your car.....?
well , yes, lol
while tinkering on Tuesday evening , and ' adjusting ' the fitment of the boot carpet trims for a more pleasing finish ( to me ) , i had to modify one of the corner carpet trims that is mounted on the card , this is the one with the plastic cover for the relays by the battery , and as i have black boot carpet ( you wont believe how hard this is to obtain ) i used parts from a tan coloured set to modify my original black set
in the process of this modification i had to refit the plastic cover , this involved drilling out the card/carpet to fit the press rivets , this is where it got painful .....
while drilling this section , and resting the back on some wood , the 100mm long 5mm drill bit broke, dont ask me how, but it did :shock:
the remaining shank that was left in the drill found its way all the way through my left thumb , in on the left of my nail, and coming out the right side of the bottom of my thumb........ :roll:
now , those of you who have been in a similar situation know its the pulling out of the drill , not the drilling in the first place thats the problem !!
duly pulled out, i staunched the now copious amounts of blood and went indoors to seek medical assistance ( a plaster from the wife ) , and considered a visit to the hospital........ as i had a hole through my thumb........
i decided against waisting their time with my stupidness, and cleaned the wound ( i am a first-aider ) , and dressed it properly and then took some pain killers ,
well, its now Saturday , the dressing is off , and the thumb is getting better enough to carry on working on the car.....
be warned..........
BB :lol:
Re: drilled a hole through my thumb !!!
Postby ptjs1 » Sat May 04, 2013 12:44 pm
BB,
Owwww! I share your pain!
Yesterday, I struggled to put two screws back into the bottom of the undertray on my X350. I was working blind, trying to balance them on the tip of a so-called magnetic tip screwdriver. Five times they dropped off into a recess that involved me having to pull off the whole undertray to retrieve them. In the end a combination of bluetac and extreme patience solved the problem. I then mused how magnetic tip screwdrivers are fairly useless, yet parts of our bodies seem to have an inate magnetism to moving hammer-heads, revolving drill bits and the high-velocity output of staple- guns. Or is it just me?
Get well soon, BB
