Reviving X350 windscreen washers
Moderators:Popsjag, J44EAG
PaulGover
Postby PaulGover » Sat Apr 27, 2013 7:21 pm
My windscreen washers started to only dribble incontinently, and then dried up completely. In case it's useful, here's details of how to fix it. Mine is a late model 350, so mileages may vary.
The washer jets are part of the wiper blade mounts, with fluid coming up a small hose clipped to the wiper arms. Detach the hose and try the washer action; if water floods out, you have blocked jets. Remove the wiper blades by lifting a plastic lever at the back of the mount, under the arm, and then the mount and blades slide out. If your jets are blocked, try some fine wire and or air (I don't recommend putting the jet in your mouth, washer fluid tastes foul :-) ) to blow the gunk back out of the jet. But my hoses just dribbled.
The hoses go to a plastic right-angle bend in the cover across the engine bay. You can pull them off to see if the blockage is in the pipe to the jets. If not, it might be the non-return valve/T-piece connected to the main feed pipe from the washer pump. At this point you need to remove the wiper arms. The round boss over the spindle is a rubber bung; insert a screwdriver in the little notch and lever it off. Mark the wiper arm positions on the windscreen with a felt-tip pen for reassembly, then undo the nuts and pull the wipers off. I had to use an old ball-joint puller; they're not that tight, just reluctant.
To access the T-piece pull the trim clips holding the bay cover down - they have a square bit in the centre that pulls up allowing the clip to shrink and flex out of the mounting holes (they are not screwed, despite looking like a demented cross-head screw). Remove the two panels filling openings on the left and right sides first - they clip in at the back and are retained by easily-broken pins at the front. Pull the main hose off the T-piece and see if there's a flow. If so, a trip to Halfords or your dealer for a new one is called for.
Mine was still dribbling, so onwards and downwards. Pull the washer reservoir filler funnel off, it's a couple of plastic barbs and an O-ring. Behind that there's a plastic plate and large diameter pipe leading into the wing. The plate's secured by another expanding plastic clip that this time looks like a cross-head screw, and may even respond to a screwdriver. Remove the plate and pipe. Now you need to remove the RH front wheel, so loosen the nuts and raise the front of the car, and remove the wheel. The washer pump and reservoir is behind the plastic wheel-arch liner. That's held by a few expanding clips (yet another variant) at the back, some Torx screws at the front, and a plastic nut to the engine bay. Then waggle it out; it's quite flexible but bloody-minded.
You should now see the reservoir. Before removing it, have a tray handy. There's a multi-plug connector at the bottom; to disconnect there's a lever at the rear that retracts the locking mechanism. Displace the two hoses running across the top front; they're aircon and air suspension pipes, so be gentle. Undo the two nuts securing the reservoir, and slide it forward, there's a projection on the back that locates its rear in the wing bracket. Pull off the outlet hose from the pump (the plastic end to the hose clips over the pump outlet), and drain the gallon of water into the tray. You did remember the tray didn't you. If not, you can use your sleeves and trousers to collect the water - I did. :-(
If yours is like mine, the reservoir had a sludgy mixture with long streamers of gluey stuff floating in it. It's very well worth removing the washer pump - the electrical connector pulls off, and you can the rotate the pump and pull it out of the rubber bush to the reservoir. Blow through it, and maybe do some electical tests if you suspect it's dead. But take a second look at the rubber bush, it pulls out easily, and reveals itself to be a filter to keep the grot out of the pump. Mine was clogged with the aformentioned gluey stuff.
Clean it all up; "assembly is the reverse of removal", as all the best books say. I filled the reservoir with a gallon of dilute bleach and pumped it through some temporary hose to a bucket, and then a gallon of water to rinse. before refitting the wiper arms. "Usefully" this exposed the fact that my battery was dying; a trip to Halfords left me 130 lb lighter. Sorry, my wallet, not me, and £ not lb :-(
Now the washers work like they used to.
Compared to my previous Jaguars (back to a Series II XJ6), the design and build quality is streets ahead, and the washers actually wash.
barrywi
Re: Reviving X350 windscreen washers
Postby barrywi » Sun Apr 28, 2013 12:28 pm
Thanks Paul for that in depth description of your problem solving. I don't suppose you have any pictures of your DIY? If it is ok with you I will pass on your post to Nigel Thorley for possible inclusion in the JEC magazine. If you do have photos please send to me barrywi@jec.org.uk.
and I will pass them on.
PaulGover
Postby PaulGover » Sun Apr 28, 2013 12:42 pm
I realised as I started typing that I should have taken photos. I could do the top end, but getting at the reservoir again means backing the car into the garage (bad for the blood pressure, it's a close fit) and putting it on the hoist (which also only just fits, so there's a lot of pushing things too and fro), and I've spent this month's energy :-). Sorry about that.
barrywi
Postby barrywi » Mon Apr 29, 2013 2:06 pm
No problem Paul , my energy is gone after day two of the month!
ionod
Postby ionod » Thu Jan 08, 2015 11:21 am
I cleaned my windscreen washers by placing a bike pump onto the union under the bonnet (left hand side under cover) I separated the union and placed the pump onto the part of hose to the windscreen washers first, gave it a few firm pumps to clear nozzles. I then placed the pump on the other part of the hose to the washer bottle. Gave it several pumps until strong bubbles in reservoir. Reconnected the hoses at the union and tried washers via switch. Problem solved and still working 6 months later. Attempting the same routine to my headlight washers later this week, to clear build up of polish from nozzles.
Hope it helps
ionod
Postby ionod » Sun Jan 11, 2015 11:52 am
Help please.
Tried unblocking headlight washers with no joy. Checked fluid level was ok and tried unblocking as previous post but nothing. How do I remove the jets from the bumper? Do I just prise them out? Finally, is there a separate pump motor for the headlight washers?
Thanks,
ionod
cdow784
Postby cdow784 » Fri Aug 09, 2019 10:36 am
Thanks for this, a great help getting my washers working again.
