Wheel 'Extended Locaters ' to assiat in refitting wheels
clivesaunders
Postby clivesaunders » Wed Apr 17, 2013 11:13 am
Hi Team
I recently saw an add for wheel 'Extended Locaters ' to assiat in refitting wheels. We all know how heavy & awkward these are to position on the hub especialy with 20" wheels .
40/50cm (16/18") in length 2 Off they screwed into the hub allowing you to locate the wheel..
..push-home... fit nuts to hold wheel..... then remove the locaters & fit all nuts.
Does anyone know where these can be obtained
Clive Newbury
GrandTourer
Re: Wheel 'Extended Locaters ' to assiat in refitting wheels
Postby GrandTourer » Wed Apr 17, 2013 12:40 pm
Hi Clive,
I bought a pair quite a few years ago now -I would not be without them for anything. By the way, I have 18" flute wheels on my car.
I first saw an article about them in the JEC mag, someone who made them for himself.
Later I saw them advertised by someone called "Zaran" or similar. I will dig back in my 'mountinous' information to see if I can find anything, but quite honestly I am not too hopeful. Maybe someone else will come up with a more accurate info.
If you have not located any and happen to come to the JEC Northern Day,
let me know and I will bring my pair with me for you to have a look at if you like.
Meantime, good luck in your search, it will definitely worth it.
Karl, XK8 MY2000 Pacific Blue
Orkney
Postby Orkney » Wed Apr 17, 2013 1:15 pm
Hi Folks,
I've been in touch with Bleasie who I believe had the pair made which were featured in the JEC.
He doesn't think anyone is making them at present. If you measure the spigot diameter on the nut and you already know the length you might need - Then i'm sure an engineering company or local retired engineer could make a pair. The thread should be no problem either for them to produce - I haven't checked my XJ8 but because of the length of the studs do they even need to be threaded? If the worst came to the worst then the wheel and adaptors would only drop back down - as the wheel does sometimes when you have no adaptors. For the number of times they are used I don't think they would mark the studs which are of a harder material than the mild steel or even aluminium alloy you would probably use. As a little luxury the they could be slightly tapered from the outer end for a couple of inches and even lightly knurled for grip for removal if you have them threaded.
Ian
aaj
Postby aaj » Thu Apr 18, 2013 12:58 am
Clive
Try http://www.XK8-Parts.com
AllanJ
XK8 Registrar
GrandTourer
Postby GrandTourer » Sat Apr 20, 2013 4:31 pm
Clive,
Here are the details of the supplier I got my items from:
Company: XKZ - Zahran Ltd
Address: 2 Cherry Acre
Chalfont St Peter
Gerrards Cross
Buckinghamshire
SL9 0SX
Contact: Chris Brueton
Telephone: 01494 875 157
Email: chriscbrueton.fsnet.co.uk
Website: www.xkz.uk.com
Profile: Specialists in the design, manufacture and supply of XK8 and XKR products for the jaguar enthusiast. Interior and exterior accessories, engine and suspension performance parts. Competitive prices, Trade enquiries welcome - XKZ Zahran Limited 01494 875 157 www.xkz.uk.com
I don't know if he still supplies them but it must be worth a call.
ATB
Karl
clivesaunders
Postby clivesaunders » Sun Apr 21, 2013 9:49 am
" Thanks Guys "... much apperciated ... at my age 66 struggeling with these heavy wheel ! !
Best
Clive
Postby Brakebuster » Sun Apr 21, 2013 11:14 am
excuse my ignorance,
but how does lifting the wheel onto extended studs differ from ' normal ' studs ?
as the process is still the same isnt it, just further away from the hub, as you still have to lift the same height , and locate the wheel over the stud........... or am i missing something ?
BB :?:
aaj
Postby aaj » Sun Apr 21, 2013 11:31 am
You don't have to lift the wheel in the same way as you are working outside of the wheel arch.
It's difficult to explain. If you ever see someone using them you'll understand the benefits.
When using the extenders you MUST screw them fully home or you will bend/snap the stud(s)
AllanJ
XK8 Registrar
GrandTourer
Postby GrandTourer » Sun Apr 21, 2013 8:59 pm
Brake Buster,
It makes a hell of a difference even so you are doing the same thing.
The main point is, you lift the wheels close to your body, rather than lift and than move them onto the wheel hub by extending your arms, than try to align the holes - phew, my back hurts only writing about it :wink: .
I have a dodgy back, but no problems since I use the extenders.
