Hi All
I little while ago i purchased a xjr V8, and it has developed a slight leak.
It looks as if the leak is coming from the underside of the super charger, and running down between the back of the 2 heads!! I have purchased a technical manual for the car on a CD, but it doesnt give me an idea of where it might be leaking from. Are there any hoses that run between the 2 heads, under the super charger. Hope someone can help.
I have bought myself an inspection camera, but cant really see anymore.
Does any 1 know how easy it is to remove the supercharger!!!! This way i might be able to see where the water is coming from.
Cheers all for taking the time to read this.
Look forward to hearing from you.
Geoff
XJR Water leak / Removing Super charger
Re: XJR Water leak / Removing Super charger
there is a coolant pipe under the s/c, this can begin to leak with old age
getting at it is a bit of a pain, David Marks recently showed us this job being done a 350 s/c, essentailly the same thing
he reckoned allow 12 hours in total do get the job done
give him a call for advice http://www.davidmarksgarages.co.uk/
hope this helps
Rob
hope this helps
Rob
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
