Hi Folks,
Yesterday, I had my nicely refurbished Speedlines fitted to the XJR-S along with some new Pirelli P6000s. While the car was up on the lift, I took the opportunity to take a good look underneath and give the wheels a good shake.
I found both front wheels had a lot of play when rocked from the top and bottom, but none when rocked from side to side. I couldn't find any play in the top or bottom ball joints. Is this a sign of the dreaded stub axle wear?
Thanks and regards,
Glenn.
A symptom of worn stub axles?
Glenn.
1989 XJR-S 6.0.
2001 X-Type 3.0 Sport.
Both in British Racing Green.
1989 XJR-S 6.0.
Stub wear
Hi glen,
I did my stub axles last year as I found significant wear on dis-assembly for disc change. I couldn't notice any difference between before and after replacement just by hand pressure on the wheels, no undue movement could be detected in any direction, just the usual minimal rock from the free play due to the bearing clearances. The difference whilst driving/under load certainly was noticeable though, much more positive in all respects!!
Nevertheless, I have to say that as the stubs wear on the lower side it would seem logical that this might be your problem (as well as possibly loose(ish) bearings), the hubs aren't hard to get off so have a look, if they're OK you can always put it back together again
