The Seasons Greetings To You!
A question if I may? Is it possible to access the rear of the speedo/rev counter without removing it from the instrument binnacle? If so how so?
I thank you in advance.
Simon
Instrument Panel
Instrument Panel
Simon, what year of car.
I have a 93, and I dont think it is possible to access the rear of the instrument cluster without removal of the pack
Its very easy to remove.
I think there are 3 screws securing the black plastic finisher, top centre and one each side.
Remove the finisher.
Remove the plastic cover clips (top corners each side). Remove the two screws.
Drop steering wheel to lowest position, ease the cluster out far enough to disconnect the 2 multiplugs, and then remove the cluster
Nigel
Nigel
Instrument Panel
Hello Nigel,
Thanks for yor reply - the car is an '88 V12.
Simon
Simon
