Rev counter panel light goes out when column shift moved
RichT
Postby RichT » Tue Nov 13, 2012 10:53 pm
Hi I have a 61 mk 2 3.4 auto with an odd gremlin, when the column change is in park the rev counter panel light works fine but as soon as you move to neutral it goes out I wonder if anyone can shed some light :mrgreen: apologies for obvious pun
RichT
Re: Rev counter panel light goes out when column shift moved
Postby RichT » Thu Nov 15, 2012 1:12 am
Got to bottom of prob, there was no earth to tachometer, when in park the clock reset cable which was hiding behind dash was making an earth, when the transmission moved into neutral cable shifted and earth broken, just thought I would post the solution in case anyone interested
JAGAZ
Postby JAGAZ » Thu Nov 15, 2012 9:46 pm
Just read this and was thinking it a connection problem aggrevated by the movement of the gear shift ,but as you say ,you`ve already found it.Wish all problems were so easilly sorted.
Proud owner of a 67 Jaguar 420.
And now an X type powered by fuel of the devil,diesel l, feel so ashamed.
PJF
Postby PJF » Thu Nov 22, 2012 9:00 pm
I echo previous comments and would add that it is nice to see an 'end of thread', ie an answer to the original posting and perhaps 'closing'the thread.
I'm sure we've all been on Boards where the initial question seems of interest but there is no conclusion, merely more 'noise'.
Amen to good manners!
