I have read on another Jag forum site that some people leave the gearbox in sport mode all the time. Will this have a detrimental effect on the gearbox.
Jeff
Sport Mode
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Re: Sport Mode
No
do it ,
much better and the power is always there when you want it , as it really just ups the revs between shifts so you get more ' umph ' and unless you kickdown harshly , the fuel consumption wont be any different
do it ,
Re: Sport Mode
Thanks BB for the prompt reply.
Jeff
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Re: Sport Mode
However, 5th gear will not engage until "economy" is selected. Fuel economy will be affected.
Re: Sport Mode
Thanks all for the replys.
On the economy front, and this is why I asked the question. According to what I have read elsewhere the 2.7 Diesel seems to achieve better MPG around town and on B roads ect on light throttle openings in sport mode.
Obviously on motorways and the like I would revert back to economy mode.
Jeff.
Jeff.
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Re: Sport Mode
I must admit my understanding of the sport button was that it simply delayed changes, as stated before. As far as I know, and I might have to bow to Mike's superior knowledge here, when cruising on motorway it will still engage 5th, even in sport mode.
XF Sportbrake 2020 / XK8 1998
Re: Sport Mode
From a previous post in the general section...
Re: Sport button
I believe the lock down to fifth gear stays put until the box senses a more cruise like speed from the driver, then it will change back up to sixth. I tend to leave the 'S' button on most of the time, unless I'm on a Motorway, or leading other JEC drivers on a Run or to a Show...zzzzz
Copied this from another forum, it was from the X350 Training Guide, but don't see why it should be any different from the S Type.
The sports mode strategy moves the transmission shift characteristics so that upshifts occur at higher engine speeds and downshifts at lower pedal angles.
In Sports mode, throttle pedal usage and cornering behaviour are monitored to assess driving style and road conditions. When an enthusiastic driving style or a demanding road is detected, sixth gear is inhibited and the lower gears are made slightly more accessible in order to prevent unwanted hunting between gears.
Conversely, when cruising conditions are detected, 6th gear is once again made available to maximise driving refinement and economy.
Under conditions of heavy braking, the transmission will perform one or more downshifts to improve response to a subsequent throttle pedal application.
Similarly if the throttle pedal is released rapidly (Fast off) following hard acceleration, one or more upshifts are inhibited to increase engine braking and also improve subsequent response.
To complement these features, when a corner is detected transmission upshifts are inhibited. This inhibition is maintained for a short distance after the corner allowing the driver to achieve a smooth balance without unwanted shifting mid-corner.
Its all clever stuff.
Doug.
Re: Sport button
Doug.
S Type Forum Moderator
Re: Sport Mode
Tried this tonight on my 5 speed.
+50mph, the sport button disengaged 5th. Back to economy mode, and back in to 5th again.
Might be different with the 6 speed.
Re: Sport Mode
I have the proper sport mode box on my 2.7d - 6-speed manual!
Redcat
Redcat
Re: Sport Mode
Leave my STR in Sport mode all the time and it uses 6th gear when travelling at a steady speed on the M'way. No noticeable difference with fuel consumption that I can tell and I prefer the change pattern...
latebreaker
Re: Sport Mode
I haven't engaged sport mode on mine...after reading Doug's post I might engage it and give it a try.
S-Type-R, 2006, Midnight, Charcoal Sport, CD Autochanger, Bluetooth, JaguarVoice and now 19" Barcelona's
Finally a Jaaag Owner, and it feels good
Petrol, The Breakfast of Champions!
It Doesn't Click or Buzz.....It ROARS
latebreaker
Re: Sport Mode
Holy Moly, I've just been driving with Sport mode engaged and....I like it! A much aggressive getaway off the line, different animal....similar to dynamic mode in the XF.
Does anyone know if the damping changes in Sport Mode?
